poachr
Everything posted by poachr
Trying to find the link for the parking brake cable on 1990 pathfinder with four wheel disks. 4x4 mt. there was a link for a guy in eBay that had NOS cables and I can’t find the link?
They do have a strap material on them, like rubber belting.
Steve, I’ll get some pictures as soon as I get home and get a chance. I’m on the road for another few days.
Thanks Steve, I’ll have to pursue this. Haven’t been able to find them anywhere yet.
To bad it only fits '94 on, I need one for a 90' rockauto is the best deal I could find $40 something
I don't have an eBay account, is that the only way to contact him? I went to the link you have in post #20 they didn't show on his site but that probably doesn't mean anything.
Steve, where did you order your cables from? I have rear disks and the drivers side cable is broke and I need one.
Steve, are you going to have the system custom made? meaning a muffler shop fit it from the manifolds back? or are you buying a system and where? I will need to be replacing mine. I was looking at the one on rockauto. Oh and mine is still the stock system so I could answer some of your questions on mounts and mounting points.
Thanks for all the feedback. I'm not out four wheeling any more those days are long past. How ever getting to some of my hunting and fishing spots gets sporty at times mud, snow and rugged. So that's why I didn't want to look at the "Performance" bake kits I'm familiar with the drilled and slotted rotors and their not really being suited to off-road. Citron on thanks for the advice but they are run out already. Checked the specs, measured then and the are at the minimum.
Hmm, never considered that. Not sure why you would want or need performance brakes on a Pathfinder? But that's the great thing about having all the different parts available to do what appeals to you, and it doesn't have to make sense.
Thanks RP88, i got several of the discount codes from the other parts I have bought from them. I can't believe that no one else from this forum hasn't purchased them.
Anyone have any experience with the rockauto brake kits? Looking at the Centric kit that has all four rotors and pads for $115.00
Yes, but I had to walk away from it for a while and think about it. I also removed the #1 plug wire and put one of the old plugs on it and had the wife crank it to see if it had spark, it did. That was the confusing part. I also replaced the the air meter boot with a new one. The old one had a big split on the bottom when I got it off. I'll probably end up having to pull the plenum, I noticed the hose on the right injector rail right behind the the upper radiator hose that has the temp sensor is leaking a bit of gas. Just enough to make the hose wet looks like a real pain to change.
Ok, so I'll get started with the fact I acquired my pathfinder just over a month ago. It's a 1990 SE 5speed with 282,000 miles. It belonged to an elderly couple who lived down the road from me, he passed away last year and she no longer drives. They also had a 1995 King cab 4x4 pickup with a 5speed that I also picked up. It has 170,000 miles both are straight and no rust. That's the great thing about living on the east side, it's dry and no salt on the roads! So back to the reason I'm submitting this. There are no service records on either vehicle and she did'nt know much about them other than he had the oil changed in them regularly and the pathfinder had a water pump put on a couple of years ago. After getting the pathfinder home and cleaning and inspecting it along with doing some quick research about them I knew the first thing I would tackle was the timing belt, tensioner, seals, AC tensioner, water pump, thermostat, hoses, belts, oil and filter change, fuel filter, plugs, wires, rotor and cap. While I was waiting I also replaced the front sway bar bushings and the tension rod bushings with the energy suspension ones. The info I got here and with youtube and Haynes, Chilton the timing belt was straight forward, just took my time and cleaned everything and straightened out some things that the last guy "Fubar'd" some people have no business owning tools!! I had the engine harness all disconnected along the front of the engine after installing the belt and setting the tension I turned the engine over 5 or 6 revolutions then was going to start it. Well guess what crank and crank and nothing, "F---" had the wife come out and turn the key on so I could hear if the fuel pump was running, it was, check all the fuses, pull the relays check all the grounds.So I check everything then take take the dust covers back of pull number 1 plug line up the cams everything is where it should be, WTF so I start putting things back so I could try cranking it again and when I reconnected the 4 plug connections on the harness on the right valve cove I noticed one of the plugs didn't look like it was all the way seated. So I pushed it all the way in and thought H mmmm, put the battery back in hoped in turned the key and it fired right off and runs like a top. So the moral of the story is never give up!! failure is never an option. Oh and changing the plugs, well #6 wasn't as bad as I thought it was going to be, #4 was a dirty mother It started to come out and wouldn't budge! so I used an old lesson I learned working on radial aircraft engines. After I got it all back together and while it was running and I was bleeding the cooling system I let it run till it was good and warm pulled it back into the shop and #4 came out! i used anti seize on all the plugs when I installed then. The plugs I pulled had been there a while. Thanks the Slartibartfast and all the others that have so generous and contributed to this site and shared their knowledge and experience.
The lower ones are the tension rod bushings. I am still getting use to the actual part names, they can be different depending on which supplier you use.
Ok, so I got the bushings changed in the front sway bar and the lower strut. I used the energy suspension ones from rock auto, wasn't to bad, I heated the ones on the front of the sway bar where they attach to the front cross member. They are pretty stiff so I put them in some hot water for about ten minutes then greased them and was able to get the clamp started over them and then used some vise grips on the side to compress them a little bit and get the bolt started. The ends on the control arms went right in. The drove it Down the road and back and they all settled into place then finished torquing them down. The lower control struts were pretty easy. i have been slowly receiving my parts timing belt, water pump, hoses, thermostat, tensioner, plugs, wires, cap and rotor so hopefully next week I can get the timing belt job started. SBF, I was able to get a Chiltons and a Haynes manual from rock auto. They're not the greatest but better than nothing! I also found the Nissan OEM parts web site and they have good diagrams.
Quick question, should I start separate posts for my Pathfinder questions? I try reading through and searching but sometimes come up short on answers. Like the timing belt, water pump change, should I get one of the all inclusive kits?
SBF, at least I’m up above all of it and just get to look down at it! Last night the area through the interchange from OLM to Tacoma was the worst.
Thanks for the invite RG and the offer, unfortunately I will be working. Please do keep me in the loop, hopefully I will be able in the future.
Hey Raingoat, don’t know about having him beat but I don’t have any traffic problems and I’ll bet SBF doesn’t either. I go in and out of SEA 2-3 times per week when I look down like to night and see all the traffic from OLM to PAE I just think wow glad I don’t have to deal with that every day.
I think I hear the click? I need someone to work the switch while I'm at the shock, getting a little hard of hearing! Did you replace the shocks? Near as I can tell the original type aren't available and if they were I doubt I could afford them! That's down the priority list for now anyway, I am doing the main things first timing belt, water pump and hoses, suspension bushings, and more cleaning! I purchased the 1995 king cab 4x4 mt from the same lady yesterday, it has 173,000 on it. Same thing with the timing belt no history. When you start it it has a noise in the engine compartment like a belt tensioner, can't really tell for sure but it might be the timing belt one? The truck is straight only bad thing is it's the Nissan purple ? Brand new at tires.
Thanks SBF, it is 24mm I got the energy suspension ones from rockauto. I'm working my way towards the timing belt, that is going to be a priority just for peace of mind. I don't need the rig so I'm taking my time going through it, lots of cleaning! I pulled the drivers side door panel and cleaned the track and lubed it, the window works better, no more hanging and dragging on the way up. Pulled the instrument cluster and cleaned and inspected. It still has the original electric shocks and I'm not sure that the "Sport/Touring" is working? The light doesn't illuminate when I select it, I think I might hear a relay click though, not sure about that either. I'm also going to do all the suspension bushings, front and back they all need it, so I have been doing lots of research on here. Thanks for the replies and sharing your knowledge and experience I'm sure I will need to rely on it. where in eastern Wa are you? I live in south eastern Or.
Slartibartfast, thanks for the link. I checked it out there is some good info. the more I look at cleaning the engine after watching the video and looking at all the relays, wiring and connectors I'm a little hesitant about spraying it down. And it aint to to bad the more I look at it. I vacuumed, whipped and used the air compressor on it.
Yea mjotrainbrain, I'm lucky where I live, rust ain't much of a problem here. It's to dry and they don't salt the roads.
