Nissman
Everything posted by Nissman
What’s your thoughts and any info would be great! I’m wanting to park my car up and start to rebuild the engine or have a changeover to the engine. I would love to keep my my beast it’s a 2002 Pathfinder Ti Vg33e engine ! I’m looking for ideas on engines and what can fit inside. My fuel is a bit heavy as you would know if you had one. But now with towing a boat it’s hurting when I do long distance. Is there any 4 cylinder Turbo D’s out there which I can fit to my Pathfinder ? If so what’s the pro’s and cons of the changeover? Sent from my iPhone using Tapatalk
Where should these brackets be attached?
Nissman replied to AlabamaDan's topic in 96-2004 R50 Pathfinders
There just a bracket to stabilise that pipe what it’s on think it’s trans fluid running through . They bolt on with the Trans Pan bolts . Sent from my iPhone using Tapatalk -
My 02 Pathy Sent from my iPhone using Tapatalk
Don't think there is mate, I've got the 2002 Vg33e and haven't come across it failing yet if there was one lol , just the water pump and thermostat I'm thinking . Sent from my iPhone using Tapatalk
I wouldn't drive it until you get it checked sounds like it's something to do with your oil pump , mine was lit up like a Christmas tree and I had a 2 klms to go till home it stalled on me and I ended up with a new engine the following week. Could be a small thing atm maybe just a connection. Sent from my iPhone using Tapatalk
New Brake Rotors and Steering Boots installed this weekend
Nissman replied to Nissman's topic in 96-2004 R50 Pathfinders
I didn't separate the balljoint on the steering arm I cracked the nut on the arm and backed it all the way out but made sure I got it close to the same position. Counted the thread starting from the inside. I still need to get a proper balance and get my camber checked after I greased up my wheel bearings and had one side which was sloppy. I had a post on here about a wobble in the front of my car not long ago I changed over my front sway bar bushes which helped but still had a knock when I steer full turn especially up the driveway or over bumps. Greased up the wheel bearings and installed them back in and solved it. Sent from my iPhone using Tapatalk -
Yeah the noise is still there But it's quieter in the rear diff but i want the noise gone . The auto switch is something to do with my Transfer gear I'm thinkin and I'm going to get a check up on Drive tomorrow see if I can sort this all out . Sent from my iPhone using Tapatalk
I had some spare time today so I thought I'd get to my seat troubles to tide me over till I either get another seat base or just sell the car [emoji23] My back isn't doing to well with my drivers seat and I had my partner drive the car and I sat in the passenger seat and I could notice the difference I've trashed my drivers seat the sponge is gone plus the leather is just wearing out I need new leather [emoji53] So for now I swapped the seats over and it worked but it was a bit of a pain you have to pull all the copper wire pins out and pull the trim off plus the sponge , they have made it hard for you to just swap them by welding the fix bolts in different places . So if your seat is a bit warn out and you want comfort again maybe swap the seat bases over took about 40 mins but worth the time. Sent from my iPhone using Tapatalk
I changed my front and rear diff fluid today and put some Nulon G70 . Looked like I didn't have the full amount of rear diff fluid in and the front was very runny like it had normal engine oil [emoji53] changed it and put some Premium oil in and it sounds much better with the rear diff hum noise is much quieter now thank god. I've bought some Transfer fluid and a front rear Uni Joint aswell today so I can change that over the rear has got a little wobble but I reckon it's still in tolerance I'll change it over just to be sure it's not damaging the transfer unit bearings - I couldn't crack the nut to fill the transfer fluid lol it's a tough one Might just be the fluids I'll get these done in a few weeks but I'll just keep an eye out I reckon it's sorted [emoji106] I just went for a drive on the highway up to about 90 km/hr on the auto and it seems better. Thanks for your input on this it's helping me get my drive back to prime again Sent from my iPhone using Tapatalk
Hope so if you had it running in auto mode just driving around would that damage it . I've been going in between 2wd and Auto on the open highway and even towing on auto I reckon . I'm thinking I've damaged it in some way . Sent from my iPhone using Tapatalk
might be the front shaft uni joint maybe but I'll have to take it out to check it's not sloppy on the drive though only seems on the inside of the unit Sent from my iPhone using Tapatalk
Ok cool Yea I might give the oil change a go I reckon my mate said put some nulon G70 with the rest of the diff oil to fill it and see if it helps it . My Drives done 300on the clock now it's starting to show its age haha , but I must say I don't do that much maintenance on it. I've already had another engine changed over in it due to my stupidity in cooking the engine with little water and then having no oil in it the second time [emoji23] Should give my Drive a little more respect at times . Some of the Pathfinders on here are getting kitted out and there looking sweet , wish they would have more Auto shops over with the car parts so cheap so I could maintain it properly. It's very pricey for parts around here or shipping is more than the part lol Sometimes you have to go through The main brand dealer for certain parts and it's twice as much. I'll give the oil change a go Sent from my iPhone using Tapatalk -
Ok guys so I need your help and guidance. When I put my 2002 Pathfinder in Auto and drive on the highway at high speed my front shaft seems to be playing up I reckon . I switch it back to 2wd and it goes away . I hopped under the car and the I can wobble the rear of the front shaft a little and it seems to be in the transfer case of it . Would that be my front and rear bearings? Would it be a hard fix ? And would I need specific tools or can I get away with normal tools . Here's the diagram it seems to be a bolt and a few bearings any one overhauled it before? Sent from my iPhone using Tapatalk
Hey guys haven't posted much for a while but found some time for my 2002 Pathfinder Ti this weekend and did a replacement on my rotors and New dust boot covers for the steering rack as one was split so changed them both . Wasn't that difficult task it helped with a little steering issue I had when full turn pulling into the driveway I had a little sound coming from the front somewhere , I reckon my front wheel bearings needed a good grease and a tad tighter . Left my brakes on as they were fine but my rotors needed replacing, just gave it all a good grease up around the area it was getting a little rusty from the seawater. Steering boots were easy to install just crack one bolt and I reckon it was a 13mm to spin the rod out of the joint connection, gave it a grease and zipped on the new boots. Should last me my life of the car now . Here's a couple of pics . Next job I want to try on the car is the rear diff I'm getting a humm coming from it when I accelerate and I've had it since I bought it any one else have this happen pls feel free to let me know what you think it might be Sent from my iPhone using Tapatalk
Excellent thankyou I'll save it this time Sent from my iPhone using Tapatalk
Hey people just asking to see if anyone has the Manual for my Pathy it's somewhere in here ! I reckon my clutch on my aircon is on it's way out. 2002 Pathy . Just need some info on the system any help would be great [emoji106]
Just thought I'd listen into this topic , I've got an A/T transmission which isn't right atm with my O/D button , it's seems to be working but my Rpms can be high aswell . I feel safer pressing the 0/D on button just to drop another gear so it doesn't seem to feel struggling at about 80km/hr . On the highway 12o km/hr my o2 Pathfinder sits about 2500 rpm that's with overdrive my car is feeling better with the O/D on . Sent from my iPhone using Tapatalk
Thanks mate took it for a 6hr drive today down to the beach and through the hills it's running ok but I have a slight rocking in the front end which might be the sway bushes or lower control arm bush not sure yet [emoji848]. Few little problem which I have to sort out . But it gets me to my favorite spots still [emoji16] Sent from my iPhone using Tapatalk
Excellent and it's all done - it didn't take to long at all about 30 mins per side and the vid was great used a rattle gun to get the bolts off and a few pics in for ya -- Easy Job to do yourself aswell . I needed rear tyres for my drive so I ended up switching my front tyres to the rear and New on the front with an alignment just in case . Thanks for your comments they all helped greatly I'm back on the Rd with new CV's Next Job soon might be my Rear Diff Bearing lol I'll keep you posted if I do this myself. Sent from my iPhone using Tapatalk
So here goes another maintenance job on my Pathy [emoji12] . I'm going to install my Cv's both sides in a couple of weeks. I've got the new springs in which is giving my 2002 Pathfinder around a 40mm lift from standard now. If you spot me any info on the do's and donts it would be great to hear from you . I'm sure it will be a learning curve for me as I've never had to do a changeover before. Sent from my iPhone using Tapatalk
Not sure I seen that pic on this site it's a good idea I want one aswell , I'll try to contact the guy with that pathy Sent from my iPhone using Tapatalk
