haydenmidd12
Everything posted by haydenmidd12
OME Lift Q's (Probably a fast answer...)
haydenmidd12 replied to PathyNewbie's topic in 96-2004 R50 Pathfinders
What is a trim packer? -
I was wanting to know the same thing I have read the reviews and some have seen improvement and some haven't
Has anyone tried the do it yourself JCR bumpers? Also are the widths of the jeep xj and the r50 about the same width?
Does anyone know the steering shaft length for a 3 inch SFD?
So they are using the honda steering or parts form the pathfinder and honda to make one ? and im going to look at prices today for the steel to drop down the subframe and if it doesnt cost that much i will probably end up going with the woodward steering just to be safe and not have to worry about modify the one i have now. unless someone has down the modify route and will help me out.
Instead of ordering a the u-joints and the shaft is there a way to modify the stock steering shaft for smaller SFD like a 2.5" SFD? Is there a way to make like a spacer for the steering shaft instead on buying a whole new steering linkage setup? If anyone has modified the stock one or maybe used other steering set ups from a differant vehicle will you let me know how you did modify it and if possible post a picture of what it looks like even if it is on your Pathfinder.
New product for the SFD Crew - SFCreation.com
haydenmidd12 replied to fleurys's topic in 96-2004 R50 Pathfinders
Is SF creation going to make a SFD? It would be awesome if you guys made it to were people can buy the steering extensions. thats the only thing holding me back from doing it -
by modified how would I do that and where could I get a new steering link from?
Where can I buy a SFD steering linkage from? or is there a way to make one?
5.- Unplug the steerig wheel conection to the rack and the pressure senso. This is the joint and the replacement part: Where did you get your steering linkage from thats the only thing I need and don't know where I can order one. and is there anyway i can just make one?
For the strut spacers does it really matter about the 8 degrees that they have to be slanted?
I want to get my truck lifted alittle in the front i have a 1.5 inch lift but it doesn't really effect anything. so i would do like a 3 inch subframe drop
I am thinking about doing a 2inch subframe spacer and doing a 2 inch strut spacers with a 1 inch or so front lift coil. and I don't think ill run into steering issues dealing with steering linkage
and what do you need for the 3 inch sub frame drop
Well I am only 2wd and I know people ask why lift a 2wd but Its like why do people at SEMA have 2wd but still. My truck has a natural nose dive. I will probably end up doing a 4 inch sub frame drop and just have the 2inch ac coils for the rear. and have a little squats and run 33s and 22x14 american forces I have a set in my garage I will probably put on there.
Does anyone know where i can get one? If I do like a 2 inch subframe drop would I need them? If I do a 2 inch subframe drop would a 3 inch strut spacer work?
for anyone that has a business and wants to get the name out there i am building my pathfinder now and is having a subframe drop and 2 inch body with 33s roof rack and i want anyone that has stickers i will send you my PO BOX and i will pay for them if i need to thanks
R50 performance upgrades. What all do you have done?
haydenmidd12 replied to haydenmidd12's topic in 96-2004 R50 Pathfinders
what exhaust do yall suggest thats for a 98 pathfinder -
Ok thank you and do have any pictures of the engine mounts by chance cause i cant seem to figure out which two it is
haydenmidd12 replied to RedRider3141's topic in The Garage
My cruise control is working it will turn on the little light but it wont set the speed any suggestions why? -
what about the strurt spacer does it need to be 4inches also?
and if i have a 4inch tall block for the subframe how tall does the engine block need to be
so call up there to order the lift or the steering linkage
