PatDes
PatDes last won the day on March 21 2019
PatDes had the most liked content!
1 Follower
    2004 R50 Chinook manual transmission
    SE Offroad
    AB
    Canada
4,128 profile views
PatDes's Achievements
  1. I ran 265 70 r17s with 0 offset wheels on my 04 before i lifted it. Had to trim just a touch of the inner fender. If you're running stock rims you probably won't even have to do that
  2. FINALLY!!! Managed to get some serious work done on my custom low profile winch bumper!! Happy will the result. Now I have to bend some tubes for the corners and finish the front skid plate AND paint it! (And fix my very messy wiring haha) Sent from my SM-A520W using Tapatalk
  3. Finally finished welding up my low profile winch bumper last week! Sent from my SM-A520W using Tapatalk
  4. Thank you! I would love a picture, if you have one! Sent from my SM-A520W using Tapatalk
  5. I'm looking to do a dual battery set up on my 2004 pathfinder. I wonder if anyone here has done it and how they positioned the batteries. Photos would be appreciated! Sent from my SM-A520W using Tapatalk
  6. Baby #1 is on the way and as I live in northern Canada a remote car starter is a must for the Pathy. Does anyone have any recommendations for a remote car starter for an 04 3.5L with a manual transmission? Thanks! Sent from my SM-A520W using Tapatalk
  7. Much appreciated Sent from my SM-A520W using Tapatalk
  8. Merry Christmas! Sent from my SM-A520W using Tapatalk
  9. How'd you get a swing gate on the stock rear bump? Sent from my SM-A520W using Tapatalk
  10. What IS the R50 rated to tow? Sent from my SM-G870W using Tapatalk
  11. Driving home after a bad few days and my 04 R50 start acting up! No top end power at all! I pull over and I can feel the engine is a little off balance. I ran the codes and I got a (cam shaft position over advanced) code. Could this be a sensor or did my timing belt skip? Sent from my SM-G870W using Tapatalk
  12. Thanks! Sent from my SM-G870W using Tapatalk
  13. This is a long shot but can anyone tell me what size the banjo fitting is for the power steering return coming off the steering rack? Sent from my SM-G870W using Tapatalk
  14. All the research I've done points to the crappy piston rings that nissan put in an otherwise amazing engine Sent from my SM-G870W using Tapatalk
  15. I have a 2004 se r50 with a 5 speed. It's done the exact same thing since I bought it over 3 years ago. I bought it knowing about the oil consumption at 170, 000 km because I was planning an engine build for it. It now has almost 270, 000. I drive it hard with over sized tires and it has seen 4 canadian mountain winters. since I have the new engine ready to go and need an excuse to do the swap, I've even stopped topping it off (except before road trips). Still runs like a champ! The thing can't be killed! Sent from my SM-G870W using Tapatalk
