Brad251
Everything posted by Brad251
  1. I have an 88 SE V6 w/ manual tranny that was supposedly recently rebuilt. Since ive had it the speedo is 7-8 mph off ex: speedo says 65 my gps speed says 57-58. I'm thinking the tranny rebuild may have some thing to do with it. Also the tranny is hard to go into 1st and 2nd gear when you first start it up. Any thoughts on both? Sent from my XT1585 using Tapatalk
  2. Not sure if they make one but they make front hitches for lots of trucks. And all the winch companies make front receiver mounts. Plus that makes it removable Sent from my XT1585 using Tapatalk
  3. You can get a rebuild kit from most any parts store. Would prolly have to order it. Auto Zone has one for $35 Sent from my XT1585 using Tapatalk
  4. Its called a taillight converter or amber turn signal converter. Universal part that gives any vehicle a pigtail that uses separate turn signals (amber). Basically a box that wires into everything on one side and a 4 way flat (pigtail) on the other Sent from my XT1585 using Tapatalk
  5. I knew something wasn't right about it. Haven't had a chance to jack it up and adjust it yet. Thanks for the measurements. Its pretty clean. Has about half of the issues all of them have: small rust spots under back seat, headlight switch issues with only 1 bright coming on. Also I'm pretty sure that's the original spare on the back. Sent from my XT1585 using Tapatalk
  6. I actually have a tool that may work. Its made for removing 3m tape that holds things together. Just to separate them. If u think it'll work. Sent from my XT1585 using Tapatalk
  7. The guy I bought it from said he adjusted the torsion to stock specs. I suspected he was not correct. Its very bumpy ride. So they may need to be re indexed and or some shocks. Not sure yet. Sent from my XT1585 using Tapatalk
  8. Just bought this recently. Can I remove the body trim (chrome strip) without damaging anything? Sent from my XT1585 using Tapatalk
  9. If a trailer has a 7 or 6 way round plug. It has trailer brakes. You can get a decent brake box for less than $100. Most boat trailers don't have electric brakes. Honestly I think most things that have electric brakes are too heavy to be towed by a Pathfinder. Sent from my XT1585 using Tapatalk
  10. Update. Yes it was the slave. Night and day difference. Sent from my XT1585 using Tapatalk
  11. I've had an 88 Pathfinder SE-V6 for a few weeks. Clutch has been fine. Today suddenly I had half pedal then all the way to floor. I have black fluid at the master on the driver firewall and the slave on the pass side bottom of the tranny looks to be leaking around the boot. So after a little googling I'm thinking the slave is bad. Any thoughts ? Sent from my XT1585 using Tapatalk
  12. I have an 88 Pathfinder I just recently purchased. Clutch had been fine then today suddenly the pedal started not coming but halfway up then nothing at all. All the way to the floor and not engaging ? Amy thoughts as to what it is ? Cable ? Linkage ? Sent from my XT1585 using Tapatalk
