cham last won the day on February 13 2024
cham had the most liked content!
About cham
- Birthday 03/10/1998
OME MD Springs all around: KYB GR-2 Struts/Gas-a-Just Shocks: 255/65r17 KO2s: Rola Rack Mod: Rear gate Storage/Trash Bag: Missing Link
2002
Gender
RVA
Country
9,139 profile views
cham's Achievements
NPORA Fulltime Resident (4/5)
17
Yeah I had thought the same thing @Slartibartfastbut even so it’d be considerably overfilled if that is the true reading. I’ll have to try and talk to a Nissan Tech that works on them a lot and get a read on what’s going on. Is that the Maxima generation with the direct injected VQ35DD @adamzan?
I’m active over in the R50 threads but my dad has a 2020 Pathfinder Rock Creek Edition. He’s had it for about a year and ever since he purchased it the oil level showed high on the side with markings. Before he bought it we took it to a Nissan Dealer to confirm it’s not overfilled and they said it’s normal as oil in the dipstick tube creates this issue and the longer you wait after shutting the engine off, the less oil that shows on the dipstick (backwards from what I’ve experienced). If I remember correctly he might have even said the back side of the dipstick (side without markings) was more accurate to the level. The owners manual says to start the engine and let it idle up to operating temp; shut it off and wait 10 minutes before checking. The photo below is after 10 minutes of the engine being shutoff but the engine had been running all morning and did not idle up to operating temp (curious if that matters). Is there anything I am missing? The oil has been changed at least 3 times by this point so I’d be very surprised the Nissan dealer is overfilling the engine!
@hawairish so I figured out why you couldn’t find the ring gasket and wire mesh gasket. In the attached photo is the inside of the cat looking from the outlet. Where the honeycomb starts is where mesh gasket and ring gasket are weirdly enough. That would suggest the entire honeycomb structure is pressed into the cat body from the inlet. Also might mean back in the day you could get the cat actually rebuilt instead of replacing the whole thing. No idea why you would need a gasket though in that location still. The photo below is the inlet side of my cat. Some chunks missing and melted, what do you think, doneski? Sent from my iPhone using Tapatalk
Okay so I'm just starting to get into it and before I go breaking any of the cat mounting studs I wanted to ask you. If you break one of the studs, you can't use the two nut method to extract them, so how did you extract the broken stud? Also, are you saying you extracted and replaced all of the studs, even if they didn't break? I was just planning to replace only the bolts and nuts if none of the studs break. Got the driver side resonator off, here’s what the outlet side of the Bank 2 cat looks like: I think that is slag meaning melted sections of honeycomb. No telling what the inlet looks like.
That's interesting. Do you think maybe the washers were crushed so much they were kind of stuck in the rim of the converter and/or manifold? Like as if they looked apart of the converter or manifold? This is straight out of the 2002 FSM; you can see it specifies the exact alignment of the washer and mesh washer: Edit: Just found what you were talking about. On RA looks like Fel-Pro 61339 is the "Mesh Washer" and 60835 is the "Washer". I can tell based on the photos. Also looks like the Fel-Pro "Mesh Washer" does reference the correct OEM P/n. They look identical to the OEM parts found on NissanPartsDeal. Can you attest to the quality of Fel-Pro for something like this? Or should I probably leave the factory washer/gaskets alone and reuse them if they are there? And I agree, no way I'm paying $90 just for these gaskets.
@hawairish did you reuse the "washer" and "mesh washer" in the exploded diagram screenshot in my original post? Maybe replacing just that washer gasket would suffice and not the mesh?
Yeah I saw some posts of people using an electric impact in its lowest setting and being careful with great success. I might try it on inconsequential stuff first. You're right, worse case scenario I can just use hose clamps in the mean time while I order the valve cover parts. Going to try to get them from oversees since they are a fraction of the cost for OEM, just might take a while.
cham started following Cat Removal , Rear Lower trailing arms 1997 Pathfinder and Car "hopping" in tight turns
Noted, I want to take off that resonator/rear-cat section off anyways to see if the pre-cats have broken apart and maybe lodged pieces within the resonator. But removing the entire exhaust would be nice so I can test for leaks off the vehicle. I'll try working at the bolts when the exhaust is warm and giving the bolts heads a nice whack before unscrewing to maybe free them up. Would you advise for or against an electric impact with extensions? Also I've got some pretty bad valve cover seepage onto my exhaust manifold/cat heat shields. The VCs are the next job after this but I wanted to address the cat issue first. If lets say I shear the heat shield bolts and can't get the shields back on during re-installation, will that increase my chances of a fire hazard since the oil will be dripping right onto the exhaust manifold? So far I haven't had any smoke just burnt smell after driving.
Hey hawairish nice to talk with you again! I was planning on removing that resonator/rear cat section with the downstream O2 sensor to give room for the pre cat egress. You’re saying that’s still not enough room? Yeah I certainly am worried about shearing off those upper 6 pre-cat fasteners. If it happens on the passenger side I don’t see how there’s anyway to remove the exhaust manifold on that side haha. Ive also wondered if maybe I should give that exhaust manifold a fresh new gasket. Are our exhaust manifolds and gasket (3.5L) ever known to crack or leak? I might do a smoke test once I remove that lower resonator section just to see if I have any manifold leaks and see if it’s worth it. Curious what an exhaust shop would charge and if they’d do it right. Did you replace the studs that connect the pre-cat to the manifold or just the nuts? Sent from my iPhone using Tapatalk
Anybody have experience with removing those pre-cats? My cats are starting to choke the engine out and I can tell the engine is struggling at highway speeds. I've had P0430/420 codes intermittent for a while now. What techniques are there to make life easier? I've been soaking as many bolts as I can get to with penetrant for a good while. I'm curious if the 6 bolt heads on the upper face/side of the cat are accessed from underneath or engine bay side. I saw a video of someone removing the entire exhaust manifold and cat as a unit for the driver side; but that looks next to impossible for the passenger side. I'm willing to remove the down pipe off the bottom of the pre-cat as well so I can lower the cat down and out. The FSM diagram makes it look like the bolt heads would be accessed from underneath shown in the figure below. Also it looks like for that upper six, some of the fasteners its a stud and separate nut where as some were just bolts. I'll probably have to remove those cat heat shields first before anything can be done. My question is, can all of this be done from underneath or will I have to remove the exhaust manifold and come from the top engine bay side?
Anybody running with gutted cats without adverse effects? I'm starting to think my catalytic converters are actually failing or clogging. Besides my P0430/P0420 codes I'm still getting, according to my scanner I'm only getting about 7 misfires averages total in the past 10 drive cycles. I can't imagine that would be the source of my issues like vibration in gear at idle and lack of power. My engine consumes so much oil I do not believe replacing with new converters would solve the issue for long. Not to mention so many things cause converters to fail and apparently it can be quick. I do not have emissions testing where I live. I'm sure it will make getting rid of the vehicle much more difficult when it comes time. Anybody been in my situation before, getting at those pre-cats is difficult and to have new ones fail soon after installing would suck. I guess if I were to replace I'd go with the Magnaflow "OEM" line. Anyone gone with cheaper brands with luck?
I’d stay away from aftermarket valve covers, never heard any good things about them and I believe NissanPartsDeal has a discount right now on most parts. I’d be interested in the aluminum valve covers as long as everything works and bolts back up like factory. Can’t say I’d be super stoked about a gap like Hawairish says between the ignition coil seal and spark plug tube if using the 2002 coils with the 2001 valve cover. Obviously replacing that #1 coil with the 2001 coil seems easy enough.
Ah I see thanks Chris! The vibration basically goes away for me if I put my transmission in neutral or park at a stoplight. If you stayed in gear in 1st while at a stoplight would it vibrate and try to stall as well? Also did you have to reprogram or perform any relearn procedures when replacing the MAF sensor? Sent from my iPhone using Tapatalk
I gotcha. I think I might replace the IACV for the hell of it next time I go in to replace my valve covers. See if I get any results. Just to be clear, you were having a full vehicle vibration at stoplights in gear once the engine is warm? It would go away in park and neutral? What is this ABS issue you were talking about? Were you saying that might have something to do with the RPM sag and vibration in gear? Sent from my iPhone using Tapatalk
Thanks for the update CamperDan, let us know if the problem comes back or not. I’ve been monitoring my g/s and it’s at about 3.6-3.7 at idle warmed up. Sounds like it’s good and I have been cleaning it over the years. Correct me if I’m wrong though, you replaced your idle air control valve at one point correct? Do you remember it fixing any vibration or stumbling back then? Also did you use oem factory MAF sensor? Sent from my iPhone using Tapatalk
