Dark94XE
About Dark94XE
- Birthday 11/07/1974
1994 XE- OME lift, Chevy Suburban wheels-machined to fit, BFG 31x10.50
Skilled/Experienced Mechanic
30-35
1994
Contact Methods
Website URL
http://
ICQ
Gender
Dark94XE's Achievements
NPORA Regular (2/5)
I have the OMEs and it rides like a Cadillac. Very happy with them. I might part the truck out. Care to make me an offer?
The bodies are almost identical from 1970 to 1978. Little things changed like turn signals and bumpers. They got heavier as they got newer. There is nothing wrong with the 260Z...except the carbs. They sucked. You could get a 260 and bolt early 240 carbs on to solve the problems they have. The early 260z had the nice small chrome bumpers, like the 240s. Half way through 74 (260Z) they changed to the 5mph bumpers which were big, ugly, and heavy. Luckily, you can put the early bumpers on the later cars (74-78).
Just try not to draw attention to yourself. The TI's or Drill Instructors will make your life a living hell. Don't fall for the old "who's a good bowler?" trick. They'll make you "latrine queen" (toilet washer). Good luck. Keep you head down and watch your back.
$4+ a gallon - what's your personal solution
Dark94XE replied to Mr. Pickles's topic in General Forums
I'm rockin' a Yamaha Razz 50cc scooter AKA "the Yamahammer". Luckily I live only about a mile away from work. It only goes 27mph. -
Oh my God, Kitta. I know this is an old thread, but how's your Dad? My father committed suicide back in '89. It changed my life forever. Kinda struck a chord when I read that. I hope everything is OK.
Interesting...better get my guns
PLEASE don't take this the wrong way... Are your tires properly inflated? I alway look at the most simple retarded thing first. Then I'd check you panhard bar.
Welcome! Take a good look at your frame. Don't be scared, they usually look really bad, but with a welder and some 1/8" plate steel, they're pretty easy to fix! Have fun with it.
I'd like to take the time to wish everyone a happy and safe new year!
HAs anyone here used a regular boat anchor for that?
See, you did not mention any other mods when you started this thread. Camshafts will absolutely change your dynamic compression ratio, although they will not change you static compression ratio. And you didn't say that you fiddled with your ECU. One of the most common things to do when tuning your ECU is to play with the knock sensor threshhold. When you do this (I don't know if you did) you ABSOLUTELY need to run higher octane fuel. Higher than 87 that is. Not know what you had done to you truck, I had assumed that you were talking about a stock motor. You need to clarify before saying that home made 94 octane will outperform 93 octane pump gas. I personally don't think you're on the ragged edge and 1 octane point would make any difference at all, but what do I know, I've only been building and working on high performance cars for 15 years. But yes I would say that you should run high octane in a motor with aftermarket cams and a tuned ECU. And you should lay off the caffine :coffee!:
I have noticed no difference in performance in my 94XE. As for the fuel prices, look at the bright side, we still have some of the cheapest gas in the world.
Thank you for the compliment on my rims. The fuel requirement for a 98 Pathy in 87 octane. I don't think you would notice any improvment in performance with using higher octane. You should use a stopwatch and check to see the difference, if any. I would be surprised, but I've been wrong before. For what it's worth, I used 93 octane in my Suby 2.5RS when it said it only required 87. I didn't see any difference in performance, but I did see a slight improvment in fuel mileage.
The the American people will swallow anything put in front of them, you know what... I'm out. I'm not going to indulge you in another pissing contest. Maybe you should come live over here for a while before you make judgements.
The American people will swallow anything put before them. Iraq is a blaring example as to how facts didn't get in the way of a 'good ol' payback patriotic war'. Nope, unfortunately the good people of the USA are too uninformed to form an opinion either way, let alone stopping another illegal war. I think this is making an unfair generalization, don't you? Aparently not, seeing that you wrote it.
