I_love_my_95_pathy
About I_love_my_95_pathy
  • Birthday 04/30/1990
    1995 NISSAN PATHFINDER LE (RWD) GREEN COLOR STOCK FAIR CONDITION REPAIRS NEEDED. MODIFICATIONS: ALL ROAD TIRE .5 INCH LIFT MORE REPAIRS AND MODIFICATIONS TO COME
    Do Not Go Off-Road
    Los Angeles CA
2,567 profile views
I_love_my_95_pathy's Achievements
NPORA Regular (2/5)
4
  1. So I've read the whole tread and was wondering if anyone knows about parts(compatibility or swap) to turn a non 4wd into stock format 4wd...sounds like I should be able to use any 4wd trans out of any pathfinder or xterra but besides that anyone know module swaps or other hiccups? Thanks in advanced
  2. Ya mine is an auto. Do you happen to know where to find the video?
  3. Idk my dad got it and brought it over to install. So I'll have to ask @ shaggy I've been fearing the same thing with the switch but it worked perfectly when it wants and other times I just get a click.
  4. Hey guys Im sure someone has already asked this or mentioned it on another topic. But i recently replaced my starter that died but I seem to be having trouble getting the soleniod to engage the starter from time to time. There are also times when the truck starts up no problem. ok now after all that. i have a second question. so you guys have anything covering your starter from the old filter?? sorry guys the first question is does anyone have a solution for a iffy starter
  5. i have taken the drivers side door panel off mine while sitting in the seat. its a bit uncomfortable but it is doable. i recommend having a flashlight and screwdriver handy
  6. But you could always do mole straps and or custom cages for the battery packs
  7. Was reading thru and the answer I had was the netting that comes in the panels. That's how I kept mine from falling out when I had my panel in full time
  8. I don't have a visor on my pathfinder and went in a similar route that your thinking but I had a goal zero nomad 20 panel with a yeti 400 in the trunk. I also charged my sherpa 50. The major problem I found was the sheer weight of any changer being attached would weight down the panels causing them to hit my head on hard bumps. If you figure a fix for this would love to hear it.
  9. Thanks for the info gonna have to find another way to get less restriction Sent from my iPhone using Tapatalk
  10. Hey guys so my 95 pathfinder LE has sprung an exhaust leak and was wondering if anyone has any idea if the VG33 exhaust might be a direct bolt on to my VG30 as a slight upgrade? Thanks for any info.
  11. hey guys so I havent quite figured out if im going to buy a compressor or try and rig a a/c compressor. hey Slartibartfast does the person you know have a write up on how he did his compressor??
  12. hey guys is anyone aware if there is a upgrade to the calipers/ brake system for the pathfinders? OEM(96-2000) or aftermarket??
  13. Hey guys so I've been contemplating trying to integrate a engine mounted compressor. But every where I have looked it mentions having to run at a higher idle. Has anyone tried to mount a high idle switch successfully? Has one been able to run a engine run compressor?
