Everything posted by MrSkaw
Id rather stay here.... Im a pathy guy at heart and if I don't keep this one I'll eventually build another Sent from my XT1254 using Tapatalk
Might give the pathfinder to my son who has helped me with build up. I would take his d21 and don't know where to go for that info.... any suggestions?
Small Block Chevy Swap worth it?
MrSkaw replied to pratt152's topic in Solid Axle Swaps, Hardcore Custom Fab
Awesome Sent from my XT1254 using Tapatalk -
Thanx guys Sent from my XT1254 using Tapatalk
Cant find the thread on rancho stabilizer
cant get to the Grass roots site
will check the centerlink out, thank you.
Evans creek, might go to Elbe hills this Sunday. Sent from my XT1254 using Tapatalk
FLTK---Color code Curt- Roof Rack Wheels I got from tire rack- they were pretty cheap, i think $88/ea running Kumo road venture MT. I like them so far.
Ill check the Paint out, it is stock and looks pretty sharp.
i went with another idler arm brace. not calmini, they took forever on suspension lift and I spent to much.
Front tire does rub, ill be putting 3" boby lift on hopefully this weekend. i cut the front out and wish i could adjust the front wheels a little forward.
Need to find some local pathfinder buddys.
Ended up pulling the hubs apart and they had one hub with a piece in backwards. Driver side did not engage. When I hit the trail I put in 4 High but did not pay attention and when on the trail we noticed that it was not engaged. Learning lesson to pay attention to the rig. Thank you guys, I was all bummed out that it was not working. ran outstanding in 2 wheel so I'm excited to run 4 wheel. Red I noticed that, thank you. I read somewhere yesterday about it as well and saw your input. I did not know how to delete it. Thought about getting lockers for the rear, I don't think that it is the factory lsd. I still use as daily driver also so wanted some input.
Was out today and could not get into 4l or high sounded like it ensure but it did not. Thank goodness buddies pulled me through tough spots. Any suggestions? Sent from my XT1254 using Tapatalk
Body lift came in today along with idler arm brace Sent from my XT1254 using Tapatalk
Got windows tinted. Sent from my XT1254 using Tapatalk
Cool, thought I'd check. Sent from my XT1254 using Tapatalk
I have three inch calmini suspension lift on right now. Ordered a three inch body lift, I can run on the same shocks correct?
94 se.. 182 Sent from my XT1254 using Tapatalk
Full wash down Sent from my XT1254 using Tapatalk
Took the spacers off, goofed the alignment up. Going to add three inch body for a 3x3. Sent from my XT1254 using Tapatalk
I want to do this when time to replace engine. First plan was to get it started with wheeling equipment. What kind of mileage do you get? I use mine as commuter and play. Sent from my XT1254 using Tapatalk
