V8path
Everything posted by V8path
Small Block Chevy Swap worth it?
V8path replied to pratt152's topic in Solid Axle Swaps, Hardcore Custom Fab
The T56 plans are still under consideration. I've been looking at the Tremec TR6060 which is the newer version of the T56, and is stronger and there are better choices of a final OD gear ratio. The older T56's were mostly .50 or .56 which (on paper) puts me at 1,600 to 1,750 RPM for highway cruising. That's a bit low for the engine for efficient power and torque., and let's face it, these projects are not built for 100 mile per hour plus runs, but it would be nice to have great highway capabilities as most of us are hours away from good off road locations, and having the engine whining at 3K plus RPM's for hours isn't great for the ears or gas conservation. This is one of those "once you start the swap", not finishing it becomes a very costly change of heart. I'm going to need a custom trans to t-case adapter, clutch linkage, etc., and new front and rear drive shafts. Outside the custom adapter, is finding a clutch that will handle the weight and torque of a truck and 35" tires. The original T-56's were never meant for that, and from the research, the clutch is a major area to address if longevity and reliability is the goal. There's no point doing this unless it performs! When this starts, the plan is to do the doubler and trans at the same time. A Pathy with 350HP, a /doubler/NP205, and 6 speed manual double over drive, would be a great thing. -
Any simple 12v test light will identify the hot wires http://www.rvdiscountsuppliers.com/test-light-12v-rv-trailer-motorhome-electrical.html
If the power to (before) the switch is good, then the issue may be after the switch, ie the driver's side window motor or wiring between the switch and motor.
Chevy Master Cylinder upgrade
V8path replied to new4x4r's topic in Solid Axle Swaps, Hardcore Custom Fab
Hey new4x4r do you have pics and the MC part numbers you used, and how you plumbed the new MC? Most of the GM MC's come with a large reservoir and small reservoir which (logic) would mean the larger reservoir should be for the larger front calipers, and the smaller reservoir for the smaller rear calipers. But the listings I found show the smaller reservoir with a larger port size (9/16-18), and the larger reservoir with a smaller port size (1/2-20). Most manufacturer's listing show the larger port (9/16) as the primary port (but that is the smaller reservoir), and the smaller port (1/2) as the secondary port (larger reservoir). Anyone able to sort out the confusion? -
Rear Bumper/Tire Swing pics for WD21
V8path replied to Jacob211's topic in Solid Axle Swaps, Hardcore Custom Fab
So far its firm, no abnormal movement or flexing. There was a lot more movement with the OEM worn bushings. I just designed the spacing so that its about 1/16" smaller spacing (between the top and bottom of the pivot tube) to put some tension on the hinge bushings, then made sure there's grease on the outer faces of the bushings. Put in a grease fitting, and it's service-able. If it wears quickly, I might try and put in a nylon washer on the bottom on each hinge. Most of the weight is on the lower flange of the bottom half of the poly bushing. The bushings are the ones used on links in in light suspensions, so they're built to take some movement and rebound. If there's any wear or softening of the bushing, it would likely only be on the bottom half. The bushing kits are about $15 and there's 4 bushings. I've only a 31" spare on it for now, and the bushings are new. Will see how it holds up when there's a 35" spare on it (my plan was to go to a metal spindle with bearings for that, but thought I'd try this - cheap parts - design for now), but for up to 33", I think it'll hold up for a while. The good thing about the poly bushings, is they will absorb any flex from the rest of the carrier. -
Thanks. It was the right price and not overly difficult to fab once I figured out the final design. Not sure how well the poly bushings will hold up but they do absorb a lot of the vibration that was the root cause of the OEM pin and bushing wear. Once the OEM pin and bushings wore a bit, there's play in the hinge and that was the source of that dreaded (metal to metal) rattle that I think all wd21 owners have experienced (given they're all at least 20 years old or more now). I added grease fittings and still need to fabricate the "stop" to hold the carrier open on uneven surfaces. -
Maybe disconnecting the exhaust might be a bit loud and not allow hearing the rattling is it is coming from the engine. The other way of doing this is having a 2nd person either trying to isolate where the noise is really coming from - have 1 person to rev the engine very very slightly (trans engaged, making sure one foot is firmly on the brake) and the other person on the side of the vehicle, and see if they can isolate where the noise if coming from. I know of a situation where a "clanking" noise was thought to be coming from the starter (flywheel/transmission area) anytime the trans was engaged or accelerating (fine when cruising). But when finally isolated, it was from the engine block, specifically the cylinder heads (the valve train), and shortly after that, the head gasket completely went and there was water coming out the exhaust. When the plugs were pulled, 2 of the plugs were damp and the coolant was low. When that was topped up, water was streaming out of the spark plug hole. The heads were pulled and we found the breach in the head gasket as the culprit.
Noises are a funny thing - in that they are sometimes hard to definitely identify the source of the noise. Have you tried isolating the noise between the exhaust system and engine? It would be loud, but if you disconnected the exhaust from the heard/exhaust manifold, and the "rattle/clanging" was still there when revving the engine, its not the exhaust. Also, from what you're saying, there is no noise when revving in neutral or park. This means there's no load on the engine, and once the trans is engaged, there is a load. My guess this is not exhaust related, but engine related. Have you done a compression test, as this sounds like a valve train issue. I've seen this, where it was the beginning of a small head gasket leak, and the extra load caused the valves to be "off" and started to make a noise any time pressure was created (such as a load on the engine). First thing is to isolated and identify....
Was going to build a tire carrier from scratch, but decided to try a different route using a set of Energy Suspension bushings, (under $20), some DOM and flat bar. Retained the OEM mounting bracket and carrier. SO far it seems to be working fairly well. Nice tight firm feel to it, and no more dreaded OEM bushing rattle. http://rs1278.pbsrc.com/albums/y516/vancouver22881/Mobile%20Uploads/IMAG1077_zpsf983fed2.jpg~320x480?t=1439080920 http://rs1278.pbsrc.com/albums/y516/vancouver22881/Mobile%20Uploads/IMAG1108_zps68bad220.jpg~c100?t=1439080920 http://rs1278.pbsrc.com/albums/y516/vancouver22881/Mobile%20Uploads/IMAG1112_zps006331f9.jpg~c100?t=1439080920 -
Thought maybe you could help on my 1997 d21 Nissan Hardbody
V8path replied to brc19761's topic in 90-95 WD21 Pathfinders
No matter what other issues you have, the cat should not be rattling like you describe. Fix that, and if the alignment is causing vibration, that's another (SAFETY) issue that should be fixed regardless of the cat. -
When you change the "tension" on the cat, this affects the amount of movement, but you say the noise is still there but bit quieter. Sounds like it might be something inside the cat which is why the noise lessens when changing the mounting tension, so whatever is inside is still rattling around. -
After a little more research, and talking to a couple guys that upgraded their Tahoe MC to a Chev 3/4T MC (NBS version), they're much happier with the braking feel and performance. The other upgrade is the power steering pump volumes and PSI. Volume should be at 3 - 3.5 GPM and PSI ideally at 1,500. With the better MC, which is essential if going to bigger calipers or converting read drums to discs, make sure the power steering pump is putting out the flow and PSI needed, otherwise this will end up being a lot of work for no performance gains -
Hey Kingman, is there a MC that you suggest would be a upgrade to the GM ones that come in leaking? Given its a GM hydro boost, and if that's not the main issue and its the MC, there should be something from another model that is a interchangeable bolt on? Most of the after market MC's I see are 3 3/16" inch spacing between the 2 mounting holes. From what I've read so far, having a power steering pump that puts out between 1,200 to 1,500 psi is ideal, and going to a 1 1/8" bore MC, along with a portioning valve is the way to go. -
Has Anyone Done A Brake Upgrade
V8path replied to christianrx7's topic in Solid Axle Swaps, Hardcore Custom Fab
Are the leaks from the hydro boost, or the MC? Been doing some research and the guys that love their hydro boost acknowledge there's extra things to do, like a oil cooler, and upgrading the steering pump, to make it work. It would seem if going the hydro boost route, be prepared to upgrade the weak parts in the system, and if its done right, you get the better performance. -
I'm considering a hydro boost upgrade http://www.nissanpathfinders.net/forum/topic/35946-chevy-master-cylinder-upgrade/. You mention having the engine running to bleed the brakes. I've not seen anything that says that is mandatory. Anyone else know if it is necessary to have the engine running during the bleeding process? Given most the wD21's are going on a quarter century or more, I haven't done it yet, but with a little modification by elongating the mounting holes slightly, the Wilwood D154 dual piston (they have a rear specific version) calipers may be a great upgrade option. The specifications for this part, on a quick glance, I think might work. If anyone gets to it it before I do, it would be nice to confirm this, as I'm sure there's a lot of OEM rear disc owners around. -
There are a few articles re going to a MC from a Turbo 300ZX (90-91 I think are the years). They have dual front ports on the opposite side, are 1 1/8", and are direct bolt on's to the Pathfinder OEM booster. If keeping it Nissan is the goal, a Nissan dual diaphragm is the way to go, but given I've already gone to GM V8 power plant, trans, Dana 44 front, with planned upgrades for a 241 doubler and NP205 (DSD from a Ford) my goal is getting the best bang for the buck, and being able to have good/easy access to replacement parts if needed. From Kingman's feedback, its not the hydro boost unit itself that's the issue, its the leaking MC's. Also, the pedal feel issue might be power steering pump or fluid flow issues. The way to go would be to look at a better/bigger MC (especially if running 35" tires) and looking at either a better quality power steering pump, or upgrade the system with a oil cooler, filter, etc. With the V8, 3/16 wall rectangular tube bumpers, 35" tires, the OEM brake system was likely never designed to stop a Pathfinder that is likely 700 - 800 lbs heavier, and needs to be able to stop if after launching it with 350 plus HP Performance has a price, and high performance needs "know how" - everything from bolt on, to custom fab/modification. This is a hobby or for some, an obsession for others, and any and all productive information is the purpose of these forums. It helps us customize our rides (for some, "our builds") which is the whole purpose of this community. -
That's always an option, but there's limited space so maybe going to a same diameter or slightly smaller diameter dual diaphragm diameter booster It really comes down to personal preference (work required and $) and have a combination of components that work well together. As for the MC, if I recall correctly, the Pathfinder OEM MC is 15/16" or 1". I went to the D52 GM 3/4 T calipers for the front, and have the OEM Nissan rear discs. So, I'm thinking a 1 1/8 MC is likely a good choice? -
So far, most of what I read is like anything. If a good system isn't set up right, or there's a weak link in the system, it won;t work right. There's good availability and pricing for GM units in the mid 2,000's year range (Tahoe, Yukon, Silverado etc.) so if the hydro boost is not the problem area, what's your guess on what it is? The MC? If that's the case, I would look at a upgrade with a compatible MC from another vehicle. That shouldn't be that hard to find? -
Thanks for info. With those numbers, they certainly made sure getting an after market fuel gauge sender is virtually non existent? Love my Pathfinder, but there's a reason to change things to a more universal parts availability when things need to be replaced or upgraded. Given the OEM tach and gas gauge is shot, I would likely be able to replace all the gauges for slightly more than what it would be to fix the existing stuff, and have all new instruments.
I was looking at the hydro boost system from a 2005 Tahoe. Have you much experience with that particular model? It looks like new4x4r had pretty good results with the 79 Blazer MC, so maybe I'll have to find a MC that will bolt up to the Tahoe system. I'm not set on any particular system other than the goal is to find a good system, or combination of interchangeable parts that is fairly easy to service and find parts if needed. Going GM is usually good when it comes to interchangeable and availability of parts, and a lot cheaper than Nissan OEM. -
Hey new4x4r, what did you use for a brake booster? You mention using a MC from 1979 Blazer - is that a pretty close fit? -
There are so many variables to mileage - tire size, ring and pinion gear ratio, tuning, whether your stomping on the gas, etc. etc. I've seen identical motor sizes in different vehicles and some have great mileage and some terrible, so what my gas mileage is won't really be the same for someone else. I had a 4.3L in before this swap, and that was about the same as the original 3.0 but the 4.3 had a lot more torque and I had gone to 4.88 gears and 33" tires. So far, the Lt1 (5.7) is a bit thirstier than the 4.3L but not by a lot if I take it easy. The problem is that with all that HP, especially since its like a new toy when I first had it out, it was almost impossible to resist the urge to stomp on the gas pedal. I've entered into the next phase of the obsession and started to get into PCM tuning with some of the LT1 software. We'll see where that leads and I'll get an update when I get around to doing some serious tuning. Part of the reason I've delayed the tuning is that I'm considering ditching the OptiSpark distributor and going to a full LS based PCM and the 8 individual coils, which allows for major tune-ability over the LT1 PCM From there I'm looking at a doubler setup with a 241 for reduction, and a NP205 (DSD), and it if makes sense (an doing a lot of homework on it still) going to a 6 speed manual T56 trans, which combined would give me double low gears for off road, and double over drive (the T56 comes with a final overdrive of .62 to .5) for the highway.
