Mehbenn
Everything posted by Mehbenn
  1. I haven't been on the forums in awhile since I only drive my pathfinder winter months and is nice see things are still going here but I installed 40in led bar also hella 500 lights on the bumper[emoji41] Sent from my SAMSUNG-SM-N920A using Tapatalk
  2. Thank you Sent from my SAMSUNG-SM-N920A using Tapatalk
  3. Sweet I was just thinking about installing these on mine where did you purchase your led kit? Sent from my SAMSUNG-SM-N920A using Tapatalk
  4. Haven't been on in awhile back to driving my patbfinder since seasons changed
  5. Yeah his r50 is bone stock I tried the reverse thing wouldn't work I'll have to crawl under and check the link and spring this weekend thanks for all the input
  6. Thanks Bushnut ill have to take a look
  7. Hi y'all not sure if this is the right spot to post I don't really post much but I love the forum and I need everyone's knowledge so my buddy has a 2003 SE it would drive perfectly fine for about 5min in 2wd then just goes into 4wd out of no where and the lever doesn't move also light doesn't turn on I put It in N pull the lever to 4h then back the 2h still stays in 4 tried everything I could think of and we replaced the transfer case fluid thought that might help but didn't ohhh and only time it goes back to 2h is when it's the pathys off hopefully some one could help thank!
  8. Any auto part store should have them I got mine from an oriellys auto parts here's a link for same one on Amazon http://www.amazon.com/gp/aw/d/B0015CIW7K?pc_redir=1414227297&robot_redir=1
  9. You should try replacing all the rubber hangers my path was doing the same thing as yours. I believe there are 5 off them
  10. Wow I love those tires I may have to get those now. I got the geolander at-s
  11. bad image but here's it installed just did it 10 minutes ago [emoji1]
  12. The adhesive is good!! In the installation packet they give you some type or primer to apply to it's sticks well Yeah the dealer ship around my area said they were discontinued and I was lucky enough to have found them on that website get them before they're gone forever
  13. Sounds like it's the abs wire I bent mine a little and it turned on . got mine at a local junkyard maybe you could do the same easy cheap fix
  14. Also if anyone wants my old ones there free local pick only Everett Washington I'll hold on for a week if not I'll toss them
  15. Hey everyone thought I'd share this info with every r50 owner anyone looking for Oem visors? you could get them for 56 some thing dollars I don't remember how much shipping was but here's the link http://www.courtesyparts.com/side-window-deflectors-set-2000-2004-pathfinder-p-227473.html?cPath=4700_5846_5848&
  16. My cv angles look okay and my front wheel alignment I had to get a camber bolt that I just bought at oreilly auto and adjusted it pretty good my tread hasn't been wearing out crazy off it's even to me that's what I have is titan wheels I'm using 2in spacers for the wheels I've been running this setup for over a year I'll try and take some pictures of the cv angles
  17. I have the same setup with ome springs with 1.5 spacers up front and 3in in the rear I fit 285/70 [emoji3]
  18. Also could get some spacers from fluerys he has a website 4x4designs.com
