94PathfinderSE
Everything posted by 94PathfinderSE
  1. I just mounted KYB Gas-A-Justs on my 94 Pathfinder two months ago. The ride is smooth and stable. Bought them as a 4 shock set from Justsuspension.com for about $160 delivered to my front door. I was looking at the Ranchos but my Explorer has the 5000s and the ride is a little unforgiving on rutted roads, the Gas-A-Just are smooth as butter. Good luck!
  2. My money is on a bent rim, but a balance job would be a good start. I had a similar issue with a bent rim on my Pathfinder when I switched over to rims I got from a totaled 02 Xterra. If it was balanced and on the rear the vibration was hardly noticeable but it was awful when the rim was on the front, balanced or not. Ended up replacing the rim in the end.
  3. There are plenty of You Tube videos on changing shocks. While I didn't see any for a WD21 the process is pretty much the same for most shocks. Watch a couple and you will get the picture. It is very simple in the rear, 2 bolts each. Fronts take a little muscle to compress the stem into the bracket but again only couple of bolts each. I just did all four corners with Gas A Just's 2 weeks ago and it took me about 2 hours including a tire rotation (figured that I might as well do it while i had the impact wrench set up) and clean up. Simple job with a huge payoff both in ride and safety. Good luck!
  4. SE- just to lazy to roll down my own window....
  5. Where am I going to find a dark grey hood?
    1. Show previous comments  1 more
    2. 94PathfinderSE
      94PathfinderSE
      That's where I get my wheels.
    3. nunya
      nunya
      they even come with tires!
    4. RedPath88
      RedPath88
      Hood: Wrecking Yard
      Dark Grey: Paint Shop
      Dark Grey Hood: Maybe Wrecking Yard, Craigslist, etc.
