fearkobe
Everything posted by fearkobe
  1. it has the 3.3. im leaning towards the radiator. Rock auto has one for 70 bucks.
  2. I'll have to look into the bleeding. I don't think we did that we just let it run with the cap off.
  3. Thanks for the reply. On our way to wa state. Started heating up going up hills the heater helps. I'm hoping it's the radiator and not the water pump. I haven't heard of a secondary thermostat but will look into it. I'm new to these. Haven't noticed any collapsed hose. I opened the radiator when it was hot and the coolant went into the coolant bottle and when I start it up it went back in the radiator.
  4. Thanks for the reply. On our way to wa state. Started heating up going up hills the heater helps. I'm hoping it's the radiator and not the water pump. I haven't heard of a secondary thermostat but will look into it. I'm new to these. Haven't noticed any collapsed hose. I opened the radiator when it was hot and the coolant went into the coolant bottle and when I start it up it went back in the radiator.
  5. I don't know if this makes a difference to the temp will rise after 75 mph.
  6. 00 pathfinder temp gauge goes up almost to 3/4 when turning on the a/c and going up hill with the a/c off. Any idea? Maybe the radiator. I did a flush and thermostat change. Thanks
  7. I'll put it down to 30 and see how it goes
  8. It's a stiffer tire then the Yokohama geo landers at that were on there before
  9. Ok so i looked up the tire and it says loading range is sl meaning standard load.
  10. I don't think it even says what loading range it is.
  11. Hello I have a 00 pathfinder se and I bought some used bridgestone dueler HL alenza 235 70 16 was wondering what would be the right tire pressure? Right now I have 38 psi. The door says 26 psi but that's with the original stock size 255 65 16. Thanks
  12. The shop I'm taking it too is gonna flush out out with radiator coolant. Before I take it in can I poor that radiator flush in there and let it idle for a little bit. I wont drive on it just get it to the shop a little early and let it idle before the flush it.
  13. Thanks I think we are gonna buy the 255 65 16 for 450 mounted and balanced it's by Westlake and they are beefy tires
  14. Had them so a pressure test and holding good. They tested the coolant for gas and exhaust nothing found and all good ready to go got our trip. Said it could of been really low on coolant.
  15. I have a set of new used 265 75 16 don't know if it will be to big
  16. I was reading to that you can put a 265 70 or 75 16. Is this true?
  17. No coolant coming out of the radiator cap pretty much just stays there. I should smell it and see. Thanks
  18. If I have it pressure tested they should be able to find it? Meaning any leaks?
  19. The 3.3 nope it runs smooth. I'll check the oil cap but the oil looks good. Thanks
  20. Last Sunday when I added almost half a gallon. Yesterday I added not nearly as much. I'm gonna have it pressure tested next week. Thanks
  21. Suppose to go out of state with it on the 2nd of next month wanna make sure we fix the leak before we leave and make sure we have no blown head gasket. Thanks for the reply I will look in that area.
