jdubs12
Everything posted by jdubs12
  1. I want to screw cup holders into my floor...obviously they will be shallow screws
  2. and the engagement point is about the same
  3. how hard is rebuilding the master/slave? could a screw driver mechanic stumble through it..?
  4. It just started happening recently, and doesnt always do it, I dont know quite how to describe the noise...its almost like air is being squeezed out. my friend described it as a baby bird that fell out of a tree then got squished while trying to call for help.. any ideas on what could cause such a thing? yeah i will work on the noise description. Also, if going from 1st to 2nd or 3rd to 2nd sometimes likes to stick will changing the transfer case fluid help? i changed transmission and it didnt do anything
  5. So my tires are pretty worn and a friend had 2 reasonably new ones that he gave me, where is the best place to put them? (yes they are the same size as the current ones) I am just wondering if the front or rear should have tires with the most tread. cheers
  6. yeah - i need one anyway i went off a cliff last weekend and was dragged out sideways by 2 tow trucks....
  7. how bad is it (to crank the tbars to go up an inch) on the front suspension? or do you guys just stay an inch higher on the back?
  8. Hey guys I have a 1995 Pathfinder XE, manual...what fluid goes in the transfer case? It says 2.25 L of Dex III but I wasn't sure... why isnt it gear oil instead of atf?
  9. precise youre just a pathfinder god eh, thanks
  10. So i have read that a lot of ppl put jeep coils in the rear for a 2" lift....this sounds cool but I have a few questions/problems to adress before pursuing it: 1) is this hard? I have my house till may 15th then move into a condo and will not be able to do vehicle work myself anymore... 2) what were the coils exactly? 3) i have rancho rs5000 on the back...not the ones used for lifts, but the guy at NAPA said they could support a lift of 1.5 - 2 " no problem....is this risky ? 4) what is required tool wise I want to do something significant to it while I have a driveway...
  11. so i swapped the 5 dash lights out and put in LEDs... it is exceptionally bright where the bulb is (but still all illuminated/easily visible) and looks super odd, can i fix this?
  12. So how do i tell if i have abs? There was no fuses for it and the bulb was pulled from the dash...ive slammed on the brakes checking for it before and nothing, and then again once i put the fuses in thinking maybe that would make it work..still no. guess i dont have it?
  13. ive never gone in deep enough to find the inner lol is swapping it out as easy as the outer?
  14. so if it was the bearings would i replace the inner and outer or just the outer or whaaat?
  15. K sweet... Midterms are almost over for me so I will def have time to fix it this weekend
  16. I checked the brakes and I can't see what it would be rubbing...it's only turning left, Id say it varies depending on speed, braking used to make it happen (going left only) but now regular left hand turns do it regardless of braking.
  17. kk will do - i feel like i should add its only when I make left hand turns, sometimes gets louder if i brake while turning
  18. Hi everyone, so recently (after some significant driving in 4x4) i noticed my front left has a terrible squeel/metal on metal rubbing noise. It has gotten worse over the last two weeks. Some recent changes are I had an alignment, swapped to winter tires (smaller then my reg. tires), and I put in new ball joints.... I am thinking (actually my friend who knows more about this @!*% is thinking) that its the bearing.... how do i tell if its garbage? That being said, anyone have any other suggestions as to what it might be? Another friend mentioned something about my axle and in which case he said i'll have a hell of a time replacing it. I will take the wheel off and have a look this weekend when I have the time. Cheers
  19. what does it look like installed/ what do you mean by not the cleanest install?
  20. can i purchase new LEDs for the two ceiling lights above the dash and the lamp in the back bench? does any1 know if you can just buy an led and stick it in there or would i need to wire resistors and crap
  21. does any1 know what size bulbs the console uses (like where the air conditioning options are)?
  22. thats sweet if someone finds out what bulbs are for a 95 im def doing that
