Stinka
Everything posted by Stinka
  1. You can't get a different shaft. 2" suspension lift on front is reliable if you wheel hard. 3" with lowered diff bushes, calmini top arms and Porsche 930 outer cvs so I'm told
  2. If its a late c200 axle like in my r20 model then yes it will be shot, as the later ones are made of @!*% steel And the diaphragm springs crack, but stay in place albeit with no Pressure on LSD clutches If its an h233b then not likely as uk r20 to '99 had this axle as well as patrols/safaris and loads of pathys and this axle (and if it is an LSD variant) is bomb proof
  3. In the uk here and those rover lumps suck, lucky to get 170bhp unless u seriously mod it Td27 will do more power but more importantly more torque and is better suited to offroad 4x4 driving, and a straight bolt in fit
  4. Stinka was my nickname in my late teens and early 20's Not because of a hygiene problem, but down to flactulance/farting I dropped my guys once when we were smoking pot around a friends and someone called me stinka and then the name stuck ...
  5. Also steering is very light now
  6. This is the kind of neg camber I have on both wheels, is very visible
  7. What's the stock length ? Need some longer ones as Ive got some serious shimming to do after 3" lift I reckon I have to add 10mm as there some serious negative and my steering is light as hell Also, what is the hardness/strength spec of the bolts Cheers
  8. UK R20 Terrano td27 '02 year Owned for about 8 months, had 138000 now done 145000 miles Hope to run it until it dies... Another 10 years methinks
  9. Was just laughing at this with my Gf and its mental the fact that the guy went straight through the middle, like the deepest part I'd have tried to hug the kerb at least ! This was at like 8am friday morning so i reckon he was still drunk from the night before ... It's the only logical explanation
  10. Either way I think his engine has sucked in water, bent rods and stuff I've no doubt
  11. We had some bad rain here last night, did this early and it was worse but didnt have my camera, this time tho some IDIOT tryed to drive through in his company work van I reckon he's in the ........ at work, especially as it was road closed and like WHAT WAS HE THINKING ANYWAY http://www.youtube.c...bed/3NuNgLcqH4E
  12. Cooper stt's tbh. The sidewall is tough as hell And just a good check on fluids etc, Cambelt if its not had one. Test the shocks for bounce and leaks and if they are tired replace with something decent and heavy duty
  13. Uk Terrano r20 ( same chassis as wd21 ) 2" suspension lift 31" cooper stt's
  14. yes im interested to know how it drives with the hubs locked in
  15. Excellent cheers How dies it drive on the road ? Does it click a lot ? Do you have manual hubs ?
  16. Subaru imprezza uses the r200 as a rear diff and has a LSD as standard Buy a wreck and just chop out and fabricate I. The rear end
  17. Cheers guys, mind is racing allready thinking about adding gussets, triangulation and all sorts
