Bluewulf73 last won the day on June 18 2013
Bluewulf73 had the most liked content!
"Wanderer" 2011 Bright Silver metallic Grand Caravan "Lenny" 2013 Sprint Grey Pearl Veloster Turbo
36-40
2011
Gender
Richmond, British Columbia
Country
Canada
Interests
My kids, cycling, 4-wheelin', camping, hiking, sailing.
Bluewulf73's Achievements
NPORA Old-Timer (5/5)
46
That looks hot!!!! Do you have photos of the whole car?
Hence the need for shells...never thought I'd see Turtles actually practicing Ninjitsu...
i thought it was sefl-adjusting...?
Wait... Pinatas are in a completely different category. Anyone that doesn't like Miatas, especially the first and last gen's is not a true petrolhead. I love Pinatas! they are sooooo much fun and can take a beating like no other roadster out there.
Looks good Darek! I forgot to recommend that you bleed the system. I hope you bled your brake system. If you haven't replaced the fluid for a while, (40,000 KM or more) I would recommend using new fluid and bleeding. Not too sure about a flush, but for sure, using new fluid and bleeding the system to get rid of air bubbles which could cause a squishy pedal feel, uneven braking and even overheating of the brake system. Is that copper compound on the hub face to prevent it and the drum from rusting and sticking to each other?
Personally, I like the Juke's look. I see in its front headlights, a frog or gator waiting to pounce. Then again, I like different-looking vehicles (except the Aztek, never liked that one). Come to think of it, the Jellybean craze (Taurus, escort2, neon, saturn, etc) of the early 21st century never really did it for me either...the only vehicle that resembled a jellybean and passed my stringent "looks" test was the Neon...then I drove it and I had such a blast I bought one!
Russian's idea of ground beef? Ouch! great video toshow motorcyclists taht don't wear leather protection...or helmuts...
Dodge/Jeep/Chrysler sells Fiat (at least here in Canada) interesting to see MOPAR supporting the aftermarket on the 500 though...Love the Abarth...
Anyone have old junk struts laying around?
Bluewulf73 replied to linkinpark's topic in 96-2004 R50 Pathfinders
if only you'd posted one month earlier...would've even met you or dropped them off somewhere in WA... -
Hey, you went to the school of hard knocks too? Cool! -Especially if you throw the word shaft in there...
Nice to see the kitteh saved... Patient dog...caraaaaaazy cat! http://www.youtube.com/watch?v=8bku2thrhSA#at=112
No tooslwforgr, it means you'll have to stop, throw it into park, get outta yer rig (unless you get ur friend/girl to do it for ya), flip the hubs, get back in, put your seatbelt on (unless yo like to live life on the edge of your seat) THEN, put it into 4wd high (or LOW). Nothing really changes, except for the fact that you have to stop to flip the hubs BEFORE engaging 4wd. Once the hubs are angaged/locked you can take it out and put it back into 4WD as many times as you want, wherever you want/need to. Don't forget to unlock them when finished wheelin' or you poor MPG and added stress to halshafts will come back.
Whoa! That looks awesome! I think the flares add a nice flair to it... Personally, I would keep the flares on...the truck looks more...uhmnn...complete. I always wanted to put flares on my Pathy but never found them at the price I wanted them. Then again, if you're going to do some heavy wheelin' keep them off and save them a nasty death. Them 33's look gnarly!
Similar to the issue I had... As bushnut states 1 of 3 things. Check: Air - Intake hose, Throttle body (for cleanliness), vacuum lines, (as many as you can - there are some hidden under the plenum) PCV valve, AIC valve (Air intake control, hidden under the plenum as well) Electrical - Battery leads, distributor cap, rotor, wires (make sure none have popped off or are loose), MAF sensor (may need a cleaning), TPS sensor, battery voltage when vehicle off and when charging ( charging should be around 14. sum'n volts) no problems starting so don't think you need to look at the starter. (Have you replaced anything electrical recently? (plugs, sensors, etc? Check those) timing... Fuel - Fuel filter, evaporative discharge cannister might be plugged, fuel filter, fuel pump, fuel pressure regulator (under the plenum). Also, have you filled up with fuel from a different gas station recently? do you experience any pinging or hesitation at all? These trucks are very finicky when it comes to the kind of fuel they drink. Lastly, check your accessory belts. Are they all there? Are you getting any whine/squeal from any of them? Could mean its not spinning the alternator as it should, preventing a full charge. My issue turned out to be too much un-metered (after the MAF and TPS) air into the engine, causing it to run too rich and stall. Good luck! Hope you find the issue sooner, rather than later. Oh, yeah...just 'cause you don't have an engine light on, does not mean your car doesn't have a soft-code. Get yourself a code reader and check for them codes... Ask me how I know...
Darek, .you've already taken it apart...in my opinion, if you have the cash and know-how do a complete, thorough cleaning of the entire brake; (on both sides/both rear brakes) as you are cleaning, make a list of what needs to be replaced. As part of your cleaning, take a wire brush to every part; if things are very rusty (such as the springs shown) make a point to replace them, check the adjustment cable and ensure to replace rusty hardware (nuts and bolts) Keep in mind this is for safety and safety should come first. Replace the same things on both sides, don't skimp. I.E.- If you replace springs on one side, do it on the other, even if the other springs look better than the first. New springs will be stronger than old ones so your braking performance might suffer if your braking forces are uneven due to the differenc between new and old springs. It looks like your piston is damaged so you will need to replace it. Again, my recommendation, if you are able to, would be to replace both. Usually when one goes, the other is not far behind (except when there has been deliberate damage) Usually, unless the shoes are fairly new and/or completely undamaged, drum and shoes are replaced together. Look for and think of uneven wear of the shoes and how that will impact the drum itself. I've seen people replace just drums or rotors only to suffer from poor braking performance or damaged brake parts. After you've cleaned and replaced, don't forget to clean the drum surface that will be touching the shoes. Again, if your budget allows, replace now. You will feel much more confidence in your truck's abilities knowing that everything will be working as it should, rather than wondering when the next thing will go.
