Dizer92Pathfinder
About Dizer92Pathfinder
  • Birthday 05/30/1982
    92 Pathfinder converted to a VG33E with a Custom Air intake system, 2 1/2 inch Exhaust with a Thrush Turbo Muffler and Limited Slip Differential. Go Custom or Go HoMe!
    SE Offroad
Contact Methods
  • Skype
    Cris.Winder
    Colorado
  • Interests
    I like to hunt,fish,camp,hike, and of course MUDDING!
6,764 profile views
Dizer92Pathfinder's Achievements
  1. I also did the VG33 Swap. Every connector goes in the same spot. I helped a guy here in Colorado do the swap too. He forgot to plug in the knock sensor that is under the intake manifold. But yes like Precise said Please post pics or atleast give us the colors of the wires at the plugs with no homes .
  2. Yo ho Yo ho . My hands a conistantly greasey and dirty . I rarely want to touch my pathy under the hood these last 6 months. BLAH!!!
  3. well yes it does come with the SE . I have it on my SE atleast!
  4. it sure is effective. When i get stuck in 4 wheel drive i turn it on for that extra power and it helps. Now on the streets in town i have no idea.
  5. Anyone want to go wheeling? send me a message. I will go with you.
  6. Will the VG30E out of a 92 pathfinder bolt up to the transmission in a 92 pickup? Please answer quick I have a guy wanting to buy my old VG30E . Would he have to do alot of Fabrication to get the VG30 into it?
  7. Life is Good With my VG33E! Sure am happy i went up to the VG33E .
    1. Tungsten
      Tungsten
      Now boost it.
  8. What year of grand cherokee and get them stock height for the jeep or find one that has a lift? What is a good website for new torsions? In doing this"lift" how much of a lift will this give me?
  9. I am needing to know if i go with https://www.4x4parts.com/nissan/pathfinder-custom-suspension-lift-p-54.html is there anything else that i will need to get to have this lift kit work besides shocks? Please help. If you know of a better suspension lift that is CHEAP and around 2 or 3 inches please let me know .
  10. Well My NOW wife and I got up to our own wedding! I put everything together just in time to leave town and get to utah! Damn the VG33E has a BIG noticeable difference then the VG30E !
    1. Show previous comments  2 more
    2. Nefarious
      Nefarious
      Ya I still need to swap those in from my old motor. I'll do it with the timing belt when I do that soon.
    3. rwd5021
      rwd5021
      Congrats on both!
    4. Slartibartfast
      Slartibartfast
      That takes balls, leaving for your wedding with a freshly swapped motor. :D Congrats.
  11. distributor is in and WoW that intake manifold was Nasty. It is new new looking now . I have alot of pics during this Conversion. I just Don't know how to post them up on this forum.
  12. I have to take off the intake manifold to get enough space to access 1 of the bolts mounting the distributor on my VG30E. On the VG33E the two bolts are easy to get to. So i will have to take off both intake manifolds to put in my VG30E distributor. I might as well Clean the intake manifold while it is off! I have to go walk to the parts place to get manifold gasket set for the VG33E so i will go and get a can of brake cleaner or carb cleaner to clean the manifold while it is off of the engine!
  13. I am nearing the end of Installing a VG33E into my 92 Pathfinder. I have both Distributors(VG30E and VG33E). I see and know they are different connectors and coil is in dist on VG33E and the cam sensor NOT Crank sensor like in VG30E. Basically It appears by all of the wiring diagrams that , IF the VG30E distributor will slide in to replace the VG33E distributor . It would be alot easier then having to re-wire connections and chase wires. I am a Good mechanic but I HATE electrical. I can do it , But it is a pain.
  14. Hi there, I have tried looking for this question or info in this and other forums. I need to know if my VG30E distributor will work in my VG33E with out putting my 3.0 crank in. I am using the VG33E crank and cams for now. I am out of money ! please help !
