arista5
Everything posted by arista5
04 Fuel Gauge question... Intermittent readings
arista5 replied to arista5's topic in 96-2004 R50 Pathfinders
sorry I had not been back since this.... Yes it worked fine while using the additive.... No it is not fixed, 4 bottles later.. doesnt work except when the additive is in. anyone have directions for changing it out? do i need to drop the tank? -
Thanks for the reply, Just bought two bottles on amazon. couldnt find any local (advance, autozone, pepboys, and dont have any chevron stations here) hopefully it works, and thank you again -
My pathfinder started doing this and now is becoming more frequent. Full tank registers full.... after about 3/4 tank then its a guessing game. I can run 200 miles and it still says 3/4 tank or it will say 1/3 tank. i would be 250m and it shows 1/2 tank. then all of a sudden the fuel light will come on and the needle drops. or it will be perfect through the entire tank. its annoying to have to watch the trip mileage just to be sure i know where i am at. its utterly frustrating, and i am asking if anyone has any clues? i couldnt find a typical ground for the fuel sender so i am guessing it may be that? any help is appreciated.
OMG what a difference. I highly recommend this. Does anyone know of a downside to it? is this putting more stress on any other part of the path that i need to keep an eye on?
they must have changed over the years.. my 04 has a Johnson Rod connected in that spot. previous years have had both a Flux Capacitor, Kuhneutson Valves, and Adjustable Power-bands.
my 04 averages 16-17mpg city. 280 miles and 17 gallons to fill (plus minus 5 miles and .5 gal at fillup) depending
WARNs or other brand Locking Hubs with stock 03/04 SE wheels?
thank you!!!! -
any local yards or someplace you can get an ECU cheaper? If you were close i would offer for you to try mine.
If you changed everything then maybe try checking your grounds. possibly one broke or even rusted off depending on what you do with your truck off road.
probably obvious but have you tried checking for spark? if you have spark then maybe a fuel/air issue no spark then an ignition issue...
ok just realized you had LE wheels not SE wheels. does anyone with the same 6 spoke wheels know if they will work? I found one other thread from a guy with an 03 SE 6 spoke and he says they wont work on his. -
will they fit if the cap is off? Whew, ordered them and was able to cancel after seeing this. -
Thank you -
good job!! nice truck too i will try the cardboard idea thank you
it did with any weight. the OE stuff was tired
I started it in my garage and decided to just go to my friends shop and use his lift as it would be easier.... Pre Lift, Measurements were 17.5" center rear to wheel well and 18.5 in the front Hub to wheel well Original Height (with one of my tool boxes in the back) after OME Med F/R, EXCEL-G, and KYB Gas A Just (same toolbox in the rear to be fair) New Measurements, 21" front and 21.5" rear to the wheel well Next will be some Sliders and Bored Titan Wheels
i hear manually locking hubs will pick up 2-3mpg
does anyone have the dimensions of a skid plate for my 04? My uncle works in a metal shop (tin knocker) and he said he would make me the plate if i gave him the dimensions. does anyone have the specs/angles? thank you
thats a smokin deal. good for you!
I bought mine from amazon 62/64 for the font pair. just-suspension.com has them for 62 each side. free shipping
Yet another EMU/AC what do I get question
Picked up the Strut Bearings and Mounts today from the Nissan Dealer. waiting on the rest. going with the EMU lift and the KYB Gas A Justs. does anyone know the best/most affordable place to buy the springs from? looks like shipping is $55 from Rocky-Road. was hoping to try and save a few bucks somewhere. ** edit ** i didnt see you posted rugged rocks has a discount. going to look for it now. thank you -
thank you, do you know the difference between the Comfort duty, HD and MD springs? rocky road only offers MD and Comfort Duty in a package or the HD and only one type as a rear -
is this cart correct for a proper strut/shock combo will this set of camber bolts work? http://www.ebay.com/itm/J-Power-FRONT-Camber-Kit-Cam-Bolt-14mm-Import-Domestic-/160708451165?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3APathfinder&vxp=mtr&hash=item256af85b5d I am still trying to figure out the springs -
from KYB and will be good reference for others like me *question removed* i realized my answer for the correct strut numbers
