tsin
Everything posted by tsin
  1. what size and type of joints u are using on the steering? thanks, Tom
  2. but, what is the best solution? change only transfer box or whole gearbox (including transfer box)? is something interchangeable or some kind of CNCmachined adapter is needed? thanks, Tom
  3. i have got same problem. There is no waggy axles in europe. but i have got vg30 engine! i dont know if i can use Patrol GR y60 2.8td or 4,2td gearbox? i think there can be a problem with different RPM of diesel vs. petrol? do you know? thx, Tom
  4. wheelin and camping in military space from 2.world war in czech republic
  5. UP. Or manual how to do "standart drum brakes" can help too
  6. I have got this manual but dont understand this scheme. Unfortunately i havent got any drum braking car before is there someone who has got photo of complete brake? Or can explain steps how to? I tried instal it like on manual image, but with a lot of fails..
  7. Hi, i changed wheel bearings on rear axle but now i have got problem to install rear parking brake. It is wd21 3.0 v6 with rear disc brakes and parking "drum" brake. Is there someone who can explain me instalation of parking brake? (with images will be better) i dont remember how it was before
  8. hi i have got a problem with idle rpm. after start is idle 2000rpm, after some driving is OK (800-900) and then sometimes back 2000rpm regardless to engine coolant temp.. i think there is a problem with vacuum lines. i describe my connection on images, is it right? or there is different fault? http://imageshack.us/f/823/20120205161131.jpg/ http://imageshack.us/f/15/20120205161202.jpg/ http://imageshack.us/f/638/20120205161229.jpg/
  9. i found an auction of one wagoneer there in europe.. My link is it good for SAS? he says that it is 1989 but dont reply to my question abour diff side edit: it has 5 wheel bolts- maybe it isnt "right wagoneer axle" for sas?!
  10. Hi, iam from czech republic and iam thinking about SAS on my 91 v6 pathy. there is nobody who has front axle (j. wagoneer dana 44, 1980-92)for sale in europe. But someone from germany offer me a jeep j20 dana44 front axle (1981, gearing 3.73). is it same like wagoneer? he says that the only difference is bolt pattern. thanks, Tom
  11. tsin
    Herculiner
    ooh, waiting for the pics
  12. can you give me some part number of your wire set (or link to buy?)? i try to buy 3 wire sets in my country and every one had different (bad) lenght.. thank you very much! Tom
  13. tsin
    Herculiner
    iam thinking about paint whole car with this bedliner ___My link___ somebody knows how it looks on pathy?
  14. ok i have crank on BTDC, set up rotor to number 1 point, and thats all? how i set 15 advance?
  15. sorry but i dont understand this instruction is possible to tell me how to? i have got this setup.. (last thing i try, was.. 30TDC on crank, insert distributor rotor- setup on their marks (5th image), move crank back to 15TDC and tighten distr.rotor screw) 1 2 3 4 5
  16. tsin
    3.0 V6 removal
    cv joints boots a front diff installed
  17. tsin
    3.0 V6 removal
    diff and cv joints boots are not installed yet.. today ill take boots from shop and try to install it
  18. tsin
    3.0 V6 removal
    solved- a3 1,9 tdi: dimension 26x86x130mm
  19. tsin
    3.0 V6 removal
    today we instal the engine in, with no problem.. we opened cv joints by plug side- more power needed (thx OlBlue), but my carparts store sell me dimensionally wrong boots.. i think there is diameter 27 and 87mm, and 103mm long.. in the Czech Republic is difficult to buy right dimension boots- is there someone who knows some other cars with dimensionally same cv joints boots??
  20. hi, i have got my front diff and engine out of car and now i need to change destroyed boots on my inner cv joints.. is there anyone who did it on wd21 v6?? thank you very much, Tom
  21. tsin
    3.0 V6 removal
    anyone who did it in real? iam so disgusted from these inner boots
  22. tsin
    3.0 V6 removal
    no, only general repair of engine.. transmission- maybe later?
  23. tsin
    3.0 V6 removal
    today removed front diff for a more place when i want to reinstall the engine.. but have another problem-> how to change inner (diff side) cv joint boot kit?????
  24. is there someone who made bodylift at home? i want to make 3 centimetres silon blocks but dont know the shape of supporting surfaces.. have you got some technical drawing to make it right?
