Danger
Everything posted by Danger
  1. Danger
    Turning noise
    Ok, I'll try that out. Is the front suspension something that should be changed out at a certain point or just fix as it needs to be?
  2. Danger
    Turning noise
    I'll go check the boot for any rips, shy of that to check it I would have to take the axel off?
  3. Soo, in the past few days I have noticed when I am making a hard right at low speeds there is a click or almost a pop from my right front wheel. My first thought was bearing, but it's not constant and not all the time. If I am sitting still and crank the wheel there is nothing. I'll probably take it to a shop tomorrow, but any ideas? Thanks
  4. I made a temporary cup holder while in the work of making nicer ones. I was told a soup can fits a cup well..... It does This was the only spare metal I had laying around, it was to support the maf, but I had a better one made. It hooks on the bottom of the driver seat and sits between my legs perfectly. Bordem can be fun.
  5. Haha thanks. Just needed work on the battery terminals. But the drinks help too.
  6. No worries, my part source is OK if you know exactly what you want, but the staff is not that helpful. Asked for a dist cap, got a dust cover....
  7. Well after cleaning and really clamping down the negative the truck seems to be starting better. At least it did at 3am after work. Thank you to everyone.
  8. Had a buddy at the engine while I was tryin to start it yesterday. He sad there was a small puff of smoke off the negative battery terminal when it clicked. The click, I'm not sure where that was from. But from what you said maybe its just cables. I'll try that out. Thanks.
  9. So, I changed the cap and rotor, everything was going fine. But when I went to start it, it clicked once and nothing happened. After playing with the new rotor, because I know it has to line up properly with everything, I got the truck started again. Let it sit overnight. Today I went to start it because I work soon and nothing, the clock goes dead and the power in the truck is lost. I take off the negative cable, played with the cap a little bit, re-attach the negative cable and it starts..... By play with the cap I mean I hit it with the side of my hand and cursed it out. In the back of my mind I'm hoping I don't have to pull the distributor and reset everything to TDC, it was working fine example prior to me changing it, just trying to do preventative maintenance. Thanks
  10. Fair, thanks. I'm trying to talk my buddy into buying a 95 se. I don't live in Ottawa anymore adam, but ill let you know next time I bring my truck to town.
  11. What site did you use and which shop? I'm in Burlington, I'm thinking that I'll be going to a speedy muffler or something like that. Not a lot of custom shops here.
  12. I get about 7L/100km city driving or 16.7mpg. Do manual hubs make a huge difference? I always drive in reverse to disengage the auto hubs.
  13. Agreed. But you can buy the stock hangers online, I was looking at them today as I have a broken one. Rockauto.com I think I was on.
  14. Yea I'm looking more free flow, 2.5" has never treated me wrong. I was just hoping there was a premade system since custom is spelt with 2 $$s most of the time.
  15. Then timing belt / water pump were done 50000kms ago. Not time yet I'd say, all the ignition system I have just replaced. When it comes to hoses and vac lines, is there a set or do I buy each individual? Sorry I may be dumb, last ride was an integra, I could find parts for that with my eyes closed. I sort of enjoy the hunt for parts, but there are no scrap yards near me. I'll have to drive closer to Toronto I guess. I'm thinking new exhaust for better air flow, any suggestions?
  16. Is there a site or store that will sell me an exhaust system or do I have to buy all parts separate and build my own system. Please keep in mind I live in Canada... Starting to really get into doing the work myself. Major scare when the engine wouldn't start today but fixed that, damned rotor spun out of place while I replacing it.
  17. Canadian Tire owns part source. But I goto both of those if I need a part asap.
  18. Oil change, tires rotated. Then did the cap and rotor...... Had a heart attack when the engine no longer worked. Had to grab the new rotor and spin in back about 5-10 degrees, such a little move made it start. Then drank.
  19. Goto each pic on photobucket. Copy the http link, then press the "landscape" looking button next to the chain and paste the link
  20. Washed her this morning, then decided it was time to take off the step bars. Then took out my broken turn signal and am currently waiting for the bondo to dry to reattach the signal. I hope it holds. Cleaned out the truck and reorganized the tool box, good day.
  21. I was told that I should probably bleed my clutch since I have had it replaced when going up hills shifting from second to third she slips sometimes; "you might have air in the lines" I was told. How hard is a fluid change?
  22. So, I've had "black betty" for just over a year now, and it has been love hate all along. I have finally decided that I'm going to keep her, so it is time to do some work. I recently took off the wheel well rust, and bondo'd painted, etc. Today I changed out the spark plugs and wires to all NGK stuff. I bought the belts to do those soon, but wondered what else you guys would suggest. I don't need a lift since its a daily driver, but might look into 31's soon. Any suggestions would be great, thanks.
  23. It does look like I am missing a few screws where that "door stay" is, maybe I'll take the door panel off and see what I can find.
  24. I did a search and see how to replace the hinge pins, but I don't have any play in my door, just the slightest breeze closes it, or if I am parked on a hill I have to keep it open with my foot. Not a massive issue, just really annoying if your hands are full. Anyone had this issue before? Thanks
