16
Towncivilian last won the day on December 10 2022
Towncivilian had the most liked content!
About Towncivilian
- Birthday 12/26/1992
3.5L 2WD A/T, 144k
16-21
Do Not Go Off-Road
2001.5
Contact Methods
Website URL
https://www.multitheftauto.com
Gender
Palm City, FL
Country
Towncivilian's Achievements
NPORA Old-Timer (5/5)
130
R50novice started following Towncivilian
Who has removed your front fender?
Towncivilian replied to jyeager's topic in 96-2004 R50 Pathfinders
My driver door hinges sag too and I've looked into replacing the hinges. It does not seem physically possible to remove and replace the hinges without removing the fender to gain access to the hinges' fasteners. -
Although this is for the passenger's side, this TSB has pretty thorough instructions on fender removal. I think it should help you out: https://drive.google.com/file/d/0B5mpmm482r0VVGVqSG9yeHJwVHM/edit?usp=sharing -
Tweeters, dome light driving me crazy
Towncivilian replied to Rebelord's topic in 96-2004 R50 Pathfinders
If you decide to keep the factory tweeters, try this mod - it really made a big difference when I was still using the Bose system. I bet the tweeters are the same for both systems. -
My bad about the wrong sensor recommendation, brain fart on my part!
10W-30 or 10W-40 is acceptable above 0F but there is no benefit over 5W-30 in the vast majority of cases.
No. It would not make a noticeable, measurable difference. 5W-20 is also not specified for our engines, use 5W-30 year round.
There are actually two "pre-cats" close to the exhaust headers, then the typical main cats you would expect afterwards which are monitored by the rear O2 sensors. At least, this is the case on VQ35DE R50s.
Not all fuel treatments are effective. Those containing PEA (polyether amine) are the most effective and is also what is found in top-tier fuels (Chevron, Shell, Mobil, etc). Fuel system cleaners containing adequate amounts of PEA are Chevron Techron (not the "ProGard fuel injector cleaner"), Gumout Regane, Redline SI-1, CRC Guaranteed To Pass (not worth the higher price over the others), probably one or two more I'm missing. I'd go for Gumout Regane from Walmart since it's the cheapest and is equally effective as Techron.
Bosch is the original sensor supplier. Bank 2 is driver's side on R50s! Bank 1 is the side with cylinder 1 (passenger) and bank 2 is the side with cylinder 2 (driver). Get this sensor from AAP, throw in a PureOne PL14610 oil filter and use coupon code TRT37 and get it all for $45.08 before any applicable tax. Pick-up in store.
No reason to use Royal Purple oil over anything else. Pennzoil has big advertising about their oils keeping engines cleaner, so try any of their oils for a while. Mobil 1 HM and just about any other high mileage oil will have a lot of detergency additives as said above. OBDII will complain if you remove the rear oxygen sensors and the cats. You shouldn't touch the cats unless they're clogged, the ECM is designed to operate with them present and I doubt you will gain any fuel economy by their removal. Use synthetic 75W-90 gear oil in the rear differential and front (if applicable). Use synthetic ATF (Valvoline MaxLife is great and is relatively inexpensive) in the transmission transfer case, and power steering. Ensure tire pressure is correct. Run a 20oz bottle of Chevron Techron fuel system cleaner through a tank of gas, then change the fuel filter. Change engine air filter if not done recently. Don't use anything higher than 89 octane. Drive less aggressively.
I'd not use them, they can damage your rotors. This page has tons of info about brake pads: https://parts.olathetoyota.com/what-are-brake-pads-made-of.html
reared by semi truck bend frame?
Towncivilian replied to EmeraldJackal's topic in 96-2004 R50 Pathfinders
Yeah, looks alright to continue driving with. I had similar, but not quite as extensive damage to the tailgate, quarter panel, and bumper. Opted to paint & replace the bumper and tailgate myself and had a shop fix the quarter panel (which is yet unpainted, urgh). -
Towncivilian replied to RedRider3141's topic in The Garage
Exactly why I recommend those products! -
NAPA store-brand conventional 5W-30 and NAPA Gold filters will work perfect for 5,000 mile oil change intervals. -
5W-30 is suitable year-round. Where do you typically purchase oil from? That will influence my suggestion for an oil filter.
