gramby1988
Everything posted by gramby1988
Hey sorry it took so long to reply would definitely like to meet around the 30 of may where exactly would you guys like to go
I finally brke down and took my pathy to a mechanic that has more knowledge than me I will let you guys know the verdict
So not having LSD isn't a bad thing I was majorly bummed. Out that I didn't have lsd
Bummer
They spin opposite
Well jacked up the rear and both wheels were spinning so I'm pretty its LSD
I will test it in the morning and see
i am curious alot of people say that my 87 xe pathfinder has lsd in the rear is that true with all v6 pathfinders or is it just certain trim.
i think i got it figured out im pretty sure its the tps i will have a brand new tomorrow i will let you guys know how it goes.
Factory service manual info offer - 87-89 Pathy
gramby1988 replied to 88pathoffroad's topic in 86.5-89 WD21 Pathfinders
I'm Having the same issue but no codes are showin up in mode three its showin code 44 but I can't go over three grand -
I was in mode three and got four greens and four reds
That's awesome I'm gonna take them off today
thats cool i will just take the front off than i wonder if there is a quick disconect setup that anyone offers. im not trying to drift mine either lol i just take my wife and kids in the truck and just wanted to make sure. thanks very much for the info.
So it should run pretty good down the hwy without to much of an issue
heres a ? is it okay to disconnect the anti sway bar on the front suspension for wheelin or does it make it easier to break something just curious because i have always had solid front axles until i bought my pathy
I'm getting four greens and four reds
Would I show a code on my Ecu if I was in safe mode because I checked the codes and it said it was normal.
sure sounds great if you wouldnt mind movin for me thanks.
still having the same issue i got the dizzy where it needs to be and when i checked it with the timing light im not getting consistent spark i am thinking it might be the coil or module or both does that make sense. any ideas?
got some a couple friends with pathfinders i would like to get some people togethor to do some wheelin here in colorado if your interested just reply.
Trying to get my path running right.
the issue started after the rebuild bought it from a friend the issue actually started after he put a new dizzy on but i can not figure it out.
clutch issue was fixed but im still having an issue with the rpm i cant figure out why my revs wont go over three grand anyone have any ideas.
Tim i am having the same issue with my 87 it wont go past three grand so i just need to use a multimeter and check for resistance on the injector clip. i have been messing with this for the last month.
