outoway
About outoway
  • Birthday 12/20/1966
    Starting over, so this one is stock at the moment
    Serious Off Road Enthusiast
Contact Methods
  • Website URL
    http://
  • ICQ
    Richmond, VA
3,759 profile views
outoway's Achievements
  1. not to hi-jack, but will the quest/villager 130 amp alt work on the pathy as well? I did that on the frontier i had previously.
  2. Is their a link to this. I may have someone that can do it.
  3. good sugestion! will try that and changing the fluid.
  4. You are right on on the Spirited driving, if i dont let off it will run up the the rev limiter if i let it. as soon as i back out of it it shifts (let off the peddle that is). As for the maint on the tranny, I was leaning towards changing the fluid, just havent had a chance. (not sure when the last maint was done on it... But it is parked at the moment till I get a chance to look into the probs!) Pathy has a new Radiator it at the moment, but I intend to put a after market cooler on.
  5. Ok, I have looked threw many topics, and still haven't found the problems that I have with mine. May have missed it though! Problems are: 1st: Going down the road with spirited driving, the tranny doesn't always shift.... if you let off a bit, she will go ahead and shift. Any ideas? 2nd: With pathy cold, if you shift into reverse, she shudders but does move. But, if she is warmed up, she does just fine. Hopefully I'm not getting ready to have to put a tranny in, but if I do, I will!
  6. those also came in metal as well. I agree that the plastic ones dont work as well.
  7. Replaced the Thermostat..... would love to strangle the engineer that put it where it is at!
  8. Cleaned out the HVAC system from all the leaves. Mounted the clip holder for my CB/mic
  9. Put new plug wires on the beast.... after the # 6 one started to arc! (3 & 5 had done it already) Oh yeah, also tightened the fuel line claps on the line between the rails! That would have been a bad mix.... fuel and an arrant spark.... could have had a flame paint job! LOL
  10. Well, put rotors and pads on the rear.... only to find that the right caliper was bad as well.... now have to finish up in the am!
  11. Actually a small inverter and a small george foreman grill and bacon comes out great!
  12. So is there any advantage on getting the 33x9.5 tires for trimming purpose? definitely would like 33's on my pathy
  13. Got my exhaust done.... now gonna need rear brakes soon!!
  14. Ok, had to go find some images.... How about a 521 for starters.... and a 620.....
