Entropy98
About Entropy98
  • Birthday 09/19/1978
    Rocky Road Super Sliders, JWT Pop-Charger, AC lift, TB spacer, 5% tint, Yakima Load Warrior, Magna Flo exuast, MB Razor wheels, 32" Firestone Destination MT, and remote starter.
    XE
Contact Methods
  • Website URL
    http://photobucket.com/albums/c11/Entropy98/
  • ICQ
    Utah
4,566 profile views
Entropy98's Achievements
NPORA Veteran (3/5)
  1. Spacers were some of the first ever made and where done by a shop close to home. I will just reuse the nuts/bolts. So what is going to be the strut that is build stronger and can take a beating? KYB vs. Gabriel? We wheel multiple times a year in Moab so it takes somewhat of a beating. Hence the STRONGER option would be better. Thanks, Tyler
  2. I guess the next best question is what is going to be the best replacement option for a vehicle that gets wheeled regularly? Is KYB the way to go or should I consider Rancho, or Monroe?
  3. Sorry but is the Excel-G the same as the GR-2. Looks different to me and I want the GR-2. I have been happy with them for the last 6 to 7 years.
  4. I have not been on here in forever but am planning on replacing my struts soon. Was wondering if I could get some info from you guys. 1. Part number for the KYB Gr-2 struts driver and passenger side. I don't want to get stuck with the Excel-G strut that they have now. 2. Other than the strut mounts/bearings, are there other parts that are suggested that need replacement. 3. I have one inch spacers on top of the struts. What is the size and length of the Grade 8 bolts that are used? I could figure this out when replacing the struts but I don't want to have to run anywhere to pick stuff up during the job. Thanks for the help in advance, Tyler
  5. I will be doing this soon. Does anyone have a link to the video mentioned in the previous post? Any heads up also on making the job easier would be appreciated as well.
  6. So with the symptoms I think that I am going to change the MAF sensor. Is there going to be any huge difference between an Auto store MAF vs. Nissan dealer MAF other than cost? If there are no significant differenced I am going to get a MAF sensor from somewhere other than the stealership. Thanks,
  7. So the code reads P0100. Checked the MAF, and cleaned all of the grounds that I could find. One of the vacume hoses could have potentially been letting air in, so i tightened the hose clamp so there was no play. We will see if that helps. That is unless anyone else has any ideas.
  8. So recenly my engine has just shut off while driving on the freeway randomly. Once the engine is to temp the RPM's will jump around and almost stall. I have changed spark plugs, coolant, belts (one of the pulleys chirps at start up), and cleaned the MAF and the intake filter. The check engine light came on and had three codes. 1. Open or short circuit condition 2. MAF/VAF sensor failure 3. Faulty ECM Ideas on where to start?
  9. Yeah I have all the PDF files of the service manual, and have looked at them extensively. Today I pulled everything apart, and have decided to take the baffle plate attached to the axle shaft to a company with a press. They will replace everything in the bearing cage including the grease seal, then press it all back onto the axle shaft. Unfortunately I have to wait till Monday to get this done. While I am at it I am also going to relace the oil seal as well as all the brake components. Thanks,
  10. Hey I have not been on the boards for quite sometime, but I need a little help/advice. I think that the rear pass axle bearing grease seal is leaking causing grease to get into the rear drum. Because of this there is no breaking power in the rear pass side. I am planning on replacing this my self and am looking for some heads up if anyone has done this before. Can I just pull the axle shaft, and replace the outer seal, or do I have to pull the bearing cage and replace/repack everything inside? Thanks, Tyler
  11. Not brake fluid, and slaves were replace with the brakes.
  12. Thanks, I am right outside of Charlotte right now. You should check out my pics on PhotoBucket (link in profile). On the 16th of this month we will be moving back to the great state of Utah. Anyone with any info on the possible axle leak?
  13. So I replaced the rear drums and shoes last month and did not feel that I gained any breaking power. I know that it would not be much, but did not feel much of a difference. So I pulled the rear right drum off and it seems that I have grease/oil that has covered a portion of the drum, and about 3/4" of the shoe. If I have a leak from the axle how involved will it be to fix and what parts will I need? I cleaned it up with break cleaner, put it back together and am going to look again tomorrow to see if there is more grease/oil that has leaked out. Thanks, Tyler
  14. Go big or go home. 32" all the way!!
