CanadianPathyNut
2002 Pathfinder LE K&N Air Intake,3" Suspension Lift, JAOS Off-Road Lights, JAOS Lamp Stay, Rockford Fossgate 1200w Amp, 12" Sony Sub, Michelin Cross Terrain Tires, Limo Tint, and a class III Hitch
2002
Contact Methods
Website URL
http://
ICQ
Laguna Beach, CA
CanadianPathyNut's Achievements
NPORA Regular (2/5)
GOT IT
i bought a trunk release solenoid, tore off the back panel on the inside of the door and attached the little metal string-wire to the hatch release on the inside of the door, I gorunded it and ran a 12g wire to the dash and installed the trunk release button, so i can open the rear window with a button, I then wired that button to my remote starter as an AUX so now I can open my rear window with the AUX button on my remote!!! GO ME!!
Did your wife leave you and take your R50?!
R50 Hidden Winch Mount recovery system
CanadianPathyNut replied to Runnerman's topic in 96-2004 R50 Pathfinders
IS IT JUST ME OR DOES IT LOOK LIKE THE FRONT BUMPER IS HALF OFF WHILE THE WINCH IS BEING USED?? RUNNERMAN? IS THIS HIDDEN MOUNT GOING TO AFFECT THE WAY MY BUMPER SITS ON MY TRUCK? CAUSE I DO NOT WANT TO HARM THE BUMPER -
did a full brake fluid flush today and could not find the LSV and now my pedal goes almost to the floor, can someone please tell me what the Load Sensing Valve looks like or tell me exactly where it is, because I could not find it and I am guessing that a 2002 LE 4x4 should have one, I need to bleed it!!! a picture would be great, thank you!
I have the Pioneer AVIC-D1 works wonders, its a great program and very easily programable, with a built in Yellow pages plus it can add waypoints without changing my final destination which i do love
the pathfinder BOSE system is a double DIN opening, when you install a "small" stereo which is a single DIN the kit that is used to make the "small" headunit fit comes with a cut out for storage under the headunit.
How many people would buy the 4 1/2" lift?
CanadianPathyNut replied to tmorgan4's topic in 96-2004 R50 Pathfinders
i would not think tiwce about it, i would for sure buy it, I would buy it right now if it was available -
if the repair kit is 2 metal strips that go down each side and some white goo that dries rick hard and 2 clamps that hold it all together then Yes, they used the kit. the day after they did it I raised the truck up on a lift and it looked as if they used a kit, thats when i figured this is a cmoon problem and it should have been a free fix
I ahde the same problem with my 02 jsut take it to a dealership its like $25 to fix,
275/70/R16's on AR767's with the AC 2" lift ME TOO
on monday I will be replacing my rootrs and pads, i heard something about needing to replace my inner bearing grease seal. where can I get a replacement one? and does anyone know where I can get really good step by step as how to d this, because this will be my first time replacing rotots and pads. i know that i need to repack the bearings so I wil be buying a good bearing grease but what else do I need??? please help me by the way I have a 2002 Pathfinder LE
anyone know where I can buy the lightbulbs for my dash? one burned out and it is the one that tells me my brites are on, i have been looking on thbe internet for 3 months now, i looked everywhere please help
i installed a trunk release solenoid and put the button up near the drivers seat then I hot wired it so I could open the rear window with the car on or off, wuite an easy install to be honest with you!
I have the rancho RS9000X with the adjustable knobs, but I really love the look of the shcoks with a resevoir. Are there any shocks available for a 2002 Pathfinder LE with the 2" AC lift? I have been searching for hours, and have found nothing, money is no object here, I jsut want a shock with a resevoir. thank you
