Missing After Powerwash
sencaw
Hey All!
Yesterday I took my front wheels off and used my pressure washer to blast the grime and grease off the lower part of the motor - both sides.
Today... it has a miss.
I did not water down the top side of engine ( except on either side of motor )
It does not miss at idle or low load, but misses like hell when I press the gas more than granny style.
Any ideas?
And as always... thank you in advance!
Remove distributor cap and spray briefly inside and on rotor with WD-40. Replace cap and see if it starts/runs normal.
Also, start it when it is dark with no lights on and see if you can see any arcing under the hood, reving it by hand.
