AlwaysWrenching Posted September 27, 2019 Share Posted September 27, 2019 I was doing a tune up and inspection on the 1997 Pathfinder I recently purchased, I discovered a small amount of play in the passenger side front wheel. However when going down the road the bearings sound find. Is possible that the backlash is set wrong but the bearings are still good? Or when there is play do you just replace and re-pack the bearings? Link to comment Share on other sites More sharing options...
Mr_Reverse Posted September 28, 2019 Share Posted September 28, 2019 If you are certain that the play is in the bearings, then it wouldn't hurt to take a look. Once you get the drive flange off, you can look at the grease in the hub. If it looks ok, I would go ahead and tighten the bearing nut a bit and if there is no noise or roughness as the wheel turns, not really worry about it. It is much better for the bearings to be a little loose than too tight. If you lived with a twin traction beam or twin I beam Ford truck, you would know all about keeping the bearings slightly loose. Link to comment Share on other sites More sharing options...
KiwiTerrano Posted September 28, 2019 Share Posted September 28, 2019 Yes, it's fairly common for the bearings to si.ply loosen with time. Both mine and my flatmates r50s have had to have the front wheel bearings tightened. Nothing wrong with the bearings, just slight excess play. You should just get them tightened and checked. They're quite tough bearings being of the taper design but will wear prematurely if loose. Link to comment Share on other sites More sharing options...
AlwaysWrenching Posted October 5, 2019 Author Share Posted October 5, 2019 Is a slight amount of play normal? I took them apart and it appears they had just been done. They do not make any noise when driving down the road. Link to comment Share on other sites More sharing options...
DesertKyle Posted October 6, 2019 Share Posted October 6, 2019 According to the fsm there shouldn't be any end play. Quite possible they just loosened up a little, I'd just snug them down. Link to comment Share on other sites More sharing options...
Inyourface1650 Posted October 6, 2019 Share Posted October 6, 2019 Funny you mention this - today I was taking a look at my brakes and had quite a lot of play on my driver tire (vertical axis). Sure enough the bearing was "look at it" loose. Waiting on the socket from Amazon to tighten it, but mine was causing some vibration on the highway. I think that but should be at something like 1.7-2inchlbs....not very tight Link to comment Share on other sites More sharing options...
Guest Posted October 6, 2019 Share Posted October 6, 2019 Funny you mention this - today I was taking a look at my brakes and had quite a lot of play on my driver tire (vertical axis). Sure enough the bearing was "look at it" loose. Waiting on the socket from Amazon to tighten it, but mine was causing some vibration on the highway. I think that but should be at something like 1.7-2inchlbs....not very tight72 ft-lb, then loosen, retighten 13 in-lbSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
