mechanic58 Posted May 28, 2018 Share Posted May 28, 2018 Anyone else have this problem? I removed the cluster and re-seated the ribbon cables, didnt seem to help. Whenever it quits working if I rap on the dash itll start working again, lol. Ordinarily its really not a big deal, but if I happen to have the cruise set it disengages when the speedo quits working. Link to comment Share on other sites More sharing options...
Slartibartfast Posted May 29, 2018 Share Posted May 29, 2018 Try tightening the brass screws on the back of the cluster. Seems to be a common cause of tach problems, might be confusing the speedo too. Link to comment Share on other sites More sharing options...
adamzan Posted May 29, 2018 Share Posted May 29, 2018 What I did was remove the brass screws and spray contact cleaner. Then use q tips to clean up the contacts. You could use fine sandpaper too. Mine has been working since I did this like 5 years ago. Link to comment Share on other sites More sharing options...
mechanic58 Posted May 29, 2018 Author Share Posted May 29, 2018 I didn't remove any of those screws but I did put a screwdriver on all of them and tighten them. Each one moved slightly. I may have to re-examine this though, thanks for the tip. Link to comment Share on other sites More sharing options...
