mechanic58 Posted April 11, 2018 Share Posted April 11, 2018 The 95 SE I just recently picked up has no heat. The engine runs the correct temp and the heater core is connected and intact. Appears to be a blend door issue. How are they actuated? Vacuum or electric servo? Link to comment Share on other sites More sharing options...
Slartibartfast Posted April 11, 2018 Share Posted April 11, 2018 No under-dash vacuum controls on these. If your climate control panel has four levers, there's a cable (like a choke cable) going from that to the blend door. If you've got two sliders and a bunch of buttons, there's a servo. The HA section of the service manual has a troubleshooting section for both systems. Looking through diagnosis for the auto system, I really hope mine doesn't quit any time soon. Looks like the manual system has a linkage to a valve to shut off the heater core. I assume the auto version has something similar. Something to check if the door isn't the problem and the core's not clogged. If you haven't yet, clean out behind your resistor pack. I doubt it's why you've got no heat but both of mine were full of trash. Link to comment Share on other sites More sharing options...
mechanic58 Posted April 11, 2018 Author Share Posted April 11, 2018 (edited) Mine has four levers so I assume its manual. The temp adj. slider has no resistance when I move it - perhaps the cable is broken or disconnected. Thanks for the info, Ill check it out. Edited April 11, 2018 by mechanic58 Link to comment Share on other sites More sharing options...
mechanic58 Posted April 11, 2018 Author Share Posted April 11, 2018 Welp, that was an easy fix! 1 Link to comment Share on other sites More sharing options...
adamzan Posted April 12, 2018 Share Posted April 12, 2018 That happened to mine as well. It fell off a few times. The ****** thing for me is it always got stuck on full heat in the middle of summer haha. 1 Link to comment Share on other sites More sharing options...
mechanic58 Posted April 12, 2018 Author Share Posted April 12, 2018 I cant figure out how it came off. After I fixed it I operated it numerous times and was not able to make it come back off. Beats me. Link to comment Share on other sites More sharing options...
adamzan Posted April 12, 2018 Share Posted April 12, 2018 I'm not sure but be prepared if it happens again. I have a long pair of needle nose pliers in the truck just in case. I tried to get a zip tie on the end of it once. No dice. 1 Link to comment Share on other sites More sharing options...
