About hardwaretoad
- Birthday 11/13/1956
All Stock SEV6 other than Yokohama 31X10.50X15's on U.S. Wheel Mod# 94's, Warn manual hubs, Kenwood cassette headunit, Kenwood single CD with frequency display underdash, Alpine 3-ways front & rear. 166,000 on the odo. Must......do........more.......reading........of......... forums !
45+
1988
Contact Methods
MSN
hardwaretoad@adelphia.net
Website URL
http://
ICQ
Gender
Yuma, Arizona
Interests
camping, hiking, photography, offroading, music, computers, computer gaming, my Pathy, women .... not in any particular order, Heck, it might be backwards now that I look at it...
2,923 profile views
hardwaretoad's Achievements
NPORA Old-Timer (5/5)
Gotta agree with that. I've had mine since '89 and believe it or not, other than updating the headlight bulbs I've replaced a grand total of one brake-light bulb in that entire time... :idea:
would like to buy new rims
hardwaretoad replied to transworldmoto's topic in 86.5-89 WD21 Pathfinders
A fine choice there, jj ... I too, am running their model 94's with the same specs, only 31x10.5 Yoko Geolander AT II's. -
Get an engine block heater for your winters. The Pathy will start easier, warm up faster, and the resultant heat transference to your tranny housing (hence, it's fluid) will make your first mile or two shifting almost as easy as it is in the summer. If that doesn't do it, you can buy a magnetic type (or glue-able) that will attach to the bottom of your tranny & plugs into any 110v power source... Sounds like your neutral safety switch has been disconnected, by-passed, or your interlock switch is constantly on... -thnkboutit-
Sorry B, I'm older & smoke ! Spend another $50. & pick up a Tsunami portable pump from your local "Pimp Boys" ~ you'll have that hummer back to operating PSI in 5-7 minutes after plugging it with no effort...
It has to do with the principals of reciprocating mass. Once you get your heavier flywheel spinning, the work your motor has to do will be much less than with the aluminum, (if indeed there is such a thing). Just because it's been lightened doesn't mean it's aluminum, the steel ones can be machined. I personally have never seen an aluminum flywheel for anything. Now, pulleys are a different matter (and area) entirely... :secret:
Best Original equipment Pathfinder
hardwaretoad replied to GreenEnvy94Pathy's topic in General Forums
Gotta go with the 1st generation, with a frame & shocks rather than the self destructing struts & a unibody... To each their own, though ~ followed a black R50 home from work tonight, we ended up along side each other at a signal, loooked each other's rigs over, thumbs up & smiled... :cool2: -
Random, the H/B truck's frame is completely different than our Pathy's ~ PU's use a leaf spring rear suspension, not a 5-link coil set-up. Has a lot to do with the differences in pricing for their respective suspension lift kits... -thnkboutit-
I gotta agree with wheelman on this "color issue"....
Welcome fellow 2-door owner ! :bow:
Will This Work found on Ebay
hardwaretoad replied to Xtreme2Pathfinder's topic in 86.5-89 WD21 Pathfinders
I don't know if this is the posting you're referring to, but I'll go ahead & provide a link to the guys fabbing these... Natch they show it on a two door... Kennesaw Moutain Accessories Ahhhh, just saw your post re: AC mount kit. Although from everything I've read here & elsewhere (except their own board, that is) I'd stay away (and have) from these guys unless absolutely neccessary... :X -
I'll third that... :X
Always a day late & a dollar short, but I finally looked at this post and got myself on there as well, great idea. Solid Snake ~ we need to get together for a cool one one of these days...
