DOA
About DOA
- Birthday 03/24/1972
1995 SE -----JGC coils in rear. Torsion bar lift up front. Custom rock sliders by yours truly.
36-40
1995
Contact Methods
Website URL
http://
ICQ
Gender
SE MI
4,133 profile views
DOA's Achievements
NPORA Veteran (3/5)
Rear locker? It will do some crazy swerving, at least mine does.
I've done the swap. You sound like you have everything you need, no special tools involved (except the clutch alignment tool which usually comes in the kit). Differentials have nothing to do with the transmission,don't worry about them. Feel free to ask me anything. Helpful hint: Fill with oil through the hole for your shifter, it's a lot easier then through the fill port. P.S It's a heavy beast, get help. I did not have any, so you can do it by yourself, but I don't recommend it.
Where does that giant windmill fit? I'm guessing it has to fold up somehow.
Place a long bar on top of your tire and get a friend (in my case it was a lawn mower) to push and hold it down. I had enough room to wiggle it out and the new one in this way. It should work better with a high lift than a floor jack cause you can get it higher. Of course all of this was concocted in my Polish head so........
Clean doesn't begin to describe that thing. Price seems good to me!
Thanks! I'll have to check that out.
Uhhhhh, I just noticed the pilot convertor thing. I didn't know about this and I don't think I removed it!!!!! The truck drives perfect though and the flywheel mounted (I thought) normally. Now I'm going to have bad dreams tonight!!!!
I just did this. Donor was a 90 into a 95. I kept the 90 transfer case, because I read somewhere that it was a heavy duty one compared to others?( feel free to chime in here) I, of course, forgot to get the speedo cable from the donor so I have no idea how fast I'm going. Actually I use a GPS to tell me, but some day i will get a cable. Hey, that leads me to a question.....Will a cable connect to mine, meaning the speedo dial on the dash?
Holy crap an air pocket!!!!! I had this same problem and I swapped my whole tranny out for a manual one. Oh well.
Whats the biggest tire I can fit under my Pathfinder. I have a 2" suspension lift and a........
Smoke coming from front in cab..burned small hole in carpet
DOA replied to NissanNismoZ's topic in The Garage
Actually I meant I welded the pipe and the floor back together. That was a while ago. I'm in the process of a transmission swap from auto to manual and have all new pipes to go in. -
My entire truck filled with smoke from this exact same problem. It was while I was doing 70 on the freeway. Lots of swerving, smoke billowing out the windows, I finally got to the shoulder. Luckily I thought to bring a fire extinguisher on this trip (the carpet was fully in flames). The cops showed up, fire trucks were called, but I had it out before any real damage. Then just like any Pathfinder owner would do, I drove it another 200 miles home. I welded it shut after that. -
Ours doesn't have any scrubber system...can you say closed by 2016!
