1995 Pathfinder A/C
Lunartic
:help: Hi there again fellas, sorry to be a pain>>> but after I had this a/c unit pressure tested and then got a new fan clutch, it seemed to be running ok. But now I can tell that it is not cooling as well as it was when I brought it in to be serviced. The fella said it was overcharged but not too much. So he drained the r134 then pressure tested then vacuum pumped it and then put back in the proper amount of r134 again. He even said that it is not as cold as it should be! When I left there it was in the evening and it was cooling good but could be better. IS THERE A PROBLEM WITH MY TXV VALVE OR A PRESSURE REGULATOR BECAUSE HE SAID THAT THE HOLES IN THE VALVE ARE PLUGGED? Is that possible and is this true???
DAMN it's hot today!!! :furious:
