gillj Posted April 14, 2006 Share Posted April 14, 2006 oK in the topic strted by Teccibal about coolant someone said that Dex-cool is a no-no because air in the system causes sludge is that true in all pathy systems or just the R-50's I have a 91 VG30 And ive been runing dexcool for about a month is this going to cause me a headache Link to comment Share on other sites More sharing options...
94extreme Posted April 14, 2006 Share Posted April 14, 2006 actually from what i gathered dexcool doesn't like being mixed with any amounts of green stuff. it's also designed for aluminum everything. not sure if our rads are al. the air has nothing to do with it as far as i could find. btw. why not just post in that other thread? Link to comment Share on other sites More sharing options...
gillj Posted April 14, 2006 Author Share Posted April 14, 2006 Because the last post in that thread was on the sixth i think so i figured id get more notice if i did a new one and ive got the a plastic and alluminum core raidiator Link to comment Share on other sites More sharing options...
FUELER Posted April 14, 2006 Share Posted April 14, 2006 (edited) Dexcool is made by GM !!!! They can't even get it to work right in their own engines!!! Keep your Japanese motors away from it! It eats the aluminum, and builds up gunk in the fins, even in GM's own motors!!! I would strongly suggest you do a good flush, and fill with any green coolant http://www.wcpo.com/wcpo/localshows/dontwa...y/20299ce7.html Edited April 14, 2006 by FUELER Link to comment Share on other sites More sharing options...
gillj Posted April 14, 2006 Author Share Posted April 14, 2006 I guess i know what ill be doing tomorrow mornign thanks guys i didnt have any idea that stuff was bad for them anyone know a really good brand of flush to use i havent had much luck with the ones ive used in the past and thanks again Link to comment Share on other sites More sharing options...
94extreme Posted April 14, 2006 Share Posted April 14, 2006 Because the last post in that thread was on the sixth i think so i figured id get more notice if i did a new one and ive got the a plastic and alluminum core raidiator it bumps up to the top when you post. Link to comment Share on other sites More sharing options...
94extreme Posted April 14, 2006 Share Posted April 14, 2006 I guess i know what ill be doing tomorrow mornign thanks guys i didnt have any idea that stuff was bad for them anyone know a really good brand of flush to use i havent had much luck with the ones ive used in the past and thanks again make sure you flush the dickens out of it. the green/orange mix is what's worse then just air. Link to comment Share on other sites More sharing options...
gillj Posted April 14, 2006 Author Share Posted April 14, 2006 Ok thanks so much again ill be flooding the thing in the morn Link to comment Share on other sites More sharing options...
gillj Posted April 14, 2006 Author Share Posted April 14, 2006 Dexcool is made by GM !!!! They can't even get it to work right in their own engines!!! Keep your Japanese motors away from it! It eats the aluminum, and builds up gunk in the fins, even in GM's own motors!!! I would strongly suggest you do a good flush, and fill with any green coolant http://www.wcpo.com/wcpo/localshows/dontwa...y/20299ce7.html Wow i just read that report it sucks to be them i guess that stuff could just be bad all the way around the funnie thing is the water pump that i put in when i did my timeing belt has this (NIFTY) little sticker on it that says "it is recommended to use dex-cool high mileage antifreeze" I guess it aint the first time manufactures directions were wrong and it sure wont be the last , (@#$%%) idiots pssd better i find out this way and not the other so thanks again Link to comment Share on other sites More sharing options...
94extreme Posted April 15, 2006 Share Posted April 15, 2006 you know, i actually am thinking of using this stuff in my truck. i'll let you know how things go.. lol Link to comment Share on other sites More sharing options...
