KIRBY Posted March 26, 2006 Share Posted March 26, 2006 Hey, I just bought my 1992 Pathfinder and i love it, it's spottless except for one problem. My fuel and temp guages do not work although in the two weeks i have owned it they have come back twice but after i shut the engin off and start it back up they are gone again. i have read that there is a sylenoid on the back of the panel but i can't find it. any suggestions? Link to comment Share on other sites More sharing options...
SteeevO Posted March 26, 2006 Share Posted March 26, 2006 i don't know about a solenoid but there is a voltage regulator. but if the operation of the guages come and goe it sounds more like a loose connection. maybe the connection on the voltage regulator... i'd pull the guages and take a look. the voltage regulator is a small silver box kinda thing .. there is a post on that around here somewhere Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 27, 2006 Share Posted March 27, 2006 Yep, voltage regulator on back of the gauge set. Link to comment Share on other sites More sharing options...
M in KC Posted March 27, 2006 Share Posted March 27, 2006 Do a search for the voltage regulator. Mr. Jim or some one did an excellent how-to on replacing this part. I did mine last year it's about a $30 part from the stealership and about a 30 minute job. An additional tip for whom ever did the write up is to use a putty knife or similar to pry the top of gauge cluster out from the dash board. GENTLY. Once out and disconnected, now is also a good time to, again gently, pry the gauge cluster's clear cover off and and get all the dust and crud out from behind it. JMTC M Link to comment Share on other sites More sharing options...
KIRBY Posted March 27, 2006 Author Share Posted March 27, 2006 hey thanks guys, i'm gonna try that tomorrow, by the way, does anyone know what the E-AT switch does? Link to comment Share on other sites More sharing options...
KIRBY Posted March 27, 2006 Author Share Posted March 27, 2006 thanks alot guys, bought the regulator today. 46.00 CAD , installed in about 15 mins works great now. Link to comment Share on other sites More sharing options...
Guest SLOPOKE Posted March 28, 2006 Share Posted March 28, 2006 You can buy the same part from any radio shack. I had to do that for my g/f's rabbit. VW wanted around $30, I picked up the part for $1.50. Works great, and havn't had a problem! Link to comment Share on other sites More sharing options...
Eli Posted March 29, 2006 Share Posted March 29, 2006 hey thanks guys, i'm gonna try that tomorrow, by the way, does anyone know what the E-AT switch does? I found this description on the internet...it's spot-on: #475 of 481 Re: "E-AT" toggle switch..... [maxpower!] by shangai Oct 31, 2005 (6:11 pm) Reply | E-mail Msg Replying to: maxpower! (Oct 13, 2005 1:51 pm) Answer: In short, it is the Power/Economy switch for the automatic transmission. For the slightly longer version this power/economy switch is similar to the sport/economy switch that can be found on other cars. The normal or default mode is the economy mode. Pressing the switch will activate the power mode, which changes the shift points by causing the transmission to shift later for an up-shift and sooner for a down shift, thus allowing the engine to rev a bit higher than it would normally in the economy mode. This power mode is useful when towing and when climbing a steep grade. Using the power mode under these conditions is most helpful in preventing the transmission from hunting or using a gear that is too high for the situation. Link to comment Share on other sites More sharing options...
