Rear Window Washer Fluid
Guest whitca
Guest whitca
Has anyone had any problems with thier rear window washer fluid stop working? Mine has for about a year and I'm not sure if there's a seperate pump or motor that needs to be replaced to push the fluid back there or if the lines are clogged with something.
Well when you try and spray the rear window do you hear a pump working? If not then the pump needs to be replaced (yes they are seperate units I'm pretty sure.) If you do hear a pump working then the lines might be clogged, start out by checking at the rear sprayer itself. Mine often clogs up, I'v found a needle is the best way to unclog the nozzles. :aok:
