'95 Pathy - Tail Light issue
prginocx
Hooked up the boat to go fishing yesterday, everything fine 'til I back into the water. Forgot to disconnect the trailer lights. After pulling out of the water I notice:
No tail lights
No instrument lights (Speedo / fuel / tach)
No Heater control lights
No ashtray light
No front / rear parking lights.
Still have:
Interior lights.
Headlights (Hi and lo beam)
Turn signals front and rear
Brake lights (rear)
Backup Lights
Didn't really have much time to examing the problem, but all the fuses are good, truck runs fine, drives fine. Little crazy to drive at night with no speedo or Tach light, but I made it home...
I DID check all the fuses in the layout under the dash just to the left of the steering column. Twice. Not one is blown. Of course not, that would be too easy.
Where are these fuses under the hood ? I do see several fusible links right off the battery hot terminal, is that what you mean ?
I did find the fuses for the Head lights. On the R-Fender well under a little plastic cover. They were also fine.
The problem turned out to be the 5 into 4 converter which I got at a junkyard for 2 bucks.
bought a new one at Uhual and installed it. All exterior lights lights working fine now. I'll have to check the interior ones when it is dark.
