dead turn signals/hazard lights
unccpathfinder
got in the truck this morning and ran up here to the library to do some research and the turn signals worked fine for like the 1st 2 turns or so and then i noticed they werent working and i pushed the hazard lights button and they didnt work either i checked the fuses in the box under the steeringwheel...im thinking its a relay or maybe a fuse under the hood any1 had this problem or know what it is.
i also installed my cb yesterday but i dont see how that could affect anything b/c i hard wired it into the fuse box under the horn fuse...(hmm idea i didnt make sure the horn still worked but the cb was so i assumed that that fuse was still good...i'll check after the library)
Double check the fuses just in case. Also check and see if you marker/parking lights are working. There is one that powers the turn signals and marker lights, and I think the dash too. I don't remember the name, but I think it was something generic like "tail" or "stop."
alright got it fixed...everything was good but i guess when i hit some bumps on campus i didnt have the plug all the way in for the hazard lights in the trim piece b/c it had come undone i plugged it back up and everything is back to working fine
yea iwas installing my cb and needed some parts from home depot, so i left the trim undone and all the wires unpluged, found out htat the blinkers wont go when the hazards arent plugged in. lucky for me no cops were around and i didnt have to use any blinkers.
