Guest 4X4pathhawg Posted March 17, 2004 Share Posted March 17, 2004 I was wondering if anybody knwos how i could put a three inch body lift on my 1990 Pathfinder...It is automatic transmission and all the lifts i have found say they don't work with automatic transmission...any suggestions?? thanks Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 17, 2004 Share Posted March 17, 2004 Any body lift for your year Pathfinder will work. The auto transmission is shifted via cable and there's tons of room for the lift. Nothing at all to worry about. Mine's an automatic and I have a Trailmaster 3" bodylift. Check here for more info on installing a body lift: http://www.damagedreality.com/tmaster.html Link to comment Share on other sites More sharing options...
statikuz Posted March 17, 2004 Share Posted March 17, 2004 Alrighty, I was considering one for my 1993, but its a manual transmission, and I've heard bad things about the shifters not working once you lift the body. Any information on this, or does someone have an installation guide along these lines? Thanks. =) Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 17, 2004 Share Posted March 17, 2004 I had to both notch the floor and bend the t-case shifter for mine. I dunno about the manual shifter, though. Link to comment Share on other sites More sharing options...
statikuz Posted March 17, 2004 Share Posted March 17, 2004 Was it tough or relatively simple? Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 17, 2004 Share Posted March 17, 2004 Kinda tough. Go read the install page I wrote for it. Link to comment Share on other sites More sharing options...
Guest Looserforyou Posted March 17, 2004 Share Posted March 17, 2004 Hey Why don't you use hockey poque to lift your path the juste cost less than 10$ and do the same job than a liftkit My friend do this on his mazda pick-up and it work verry good Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 17, 2004 Share Posted March 17, 2004 Because you'd have to buy 20 hockey pucks to even start to make a 3" lift(5 body mounts per side, 2 pucks per mount for 3"), and you wouldn't get any of the relocation brackets or extension hoses or instructions that come with the kit. Link to comment Share on other sites More sharing options...
Guest Looserforyou Posted March 18, 2004 Share Posted March 18, 2004 oh sorry I didn't see 3 inch that's different Link to comment Share on other sites More sharing options...
statikuz Posted March 29, 2004 Share Posted March 29, 2004 Anyone know of a good body lift kit for a '93 Pathfinder OTHER than the one AC sells? I checked with Trailmaster and Performance Accessories, but I guess their kits stop at the '90 year. I'm not sure if it matters or not, but if anyone knows of a good, high-quality kit for my era of Pathy...? =) Link to comment Share on other sites More sharing options...
BigMike Posted March 29, 2004 Share Posted March 29, 2004 how brittle is a hockey puck? Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 29, 2004 Share Posted March 29, 2004 I'd think they're pretty resilient, considering that they get smacked around by hockey sticks on ice all night long... Link to comment Share on other sites More sharing options...
statikuz Posted March 30, 2004 Share Posted March 30, 2004 Bump. Anyone have any info on my question above? =) C'mon 88... if you're gonna tell people not to shop AC then toss out some alternatives. =) Thanks... Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 30, 2004 Share Posted March 30, 2004 Truth is, AC retrofits those body lift kits so they'll fit a 90-up Pathy. All the kit needs is longer body mount bolts for the rear mounts, I think. That and the radiator brackets, I guess. I could be wrong, though. If you do a search on the AC forum I bet you'll find out what they do to make the kit fit. Link to comment Share on other sites More sharing options...
statikuz Posted March 30, 2004 Share Posted March 30, 2004 Yep, that's pretty much it as far as I read... they just include different bolts I think... you have to buy the radiator kit separately, or so I understood. Still wary about the shifter problems though, do they cause issues with just the t-case shifter or the gearshift as well? I've got a manual tranny and I'm not sure if I want to screw with trying to lengthen the shifters, etc. etc... thanks in advance. =) update: Not sure what this means, the description that AC has for the body lift says "transmission & transfer case extension". What's that mean? And you're right, "Special grade 8 bolts added for 90-95 Pathfinder applications." Link to comment Share on other sites More sharing options...
Soccerstudd5 Posted April 18, 2007 Share Posted April 18, 2007 Statikuz: did you ever find out about what the shifter and t-case extensions were? I'm going to be doing that lift soon and hadn't noticed that until now and it makes me a little weary of doing it as well. Let me know if anyone's found out about that and how extensive it REALLY is. Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted April 18, 2007 Share Posted April 18, 2007 it's not that big a deal, either notch the floor & bend the lever, or go to the junkyard & get a hardbody lever. Link to comment Share on other sites More sharing options...
LD50 Posted April 18, 2007 Share Posted April 18, 2007 The trans shifter is not a problem, you may just need to bend your tcase shifter or notch the floor, thats the best and easiest route. Link to comment Share on other sites More sharing options...
Soccerstudd5 Posted April 18, 2007 Share Posted April 18, 2007 Alright thanks guys! It'll be a little while (month or so) before I do this mod, but if I run into any problems, I know who to ask! Link to comment Share on other sites More sharing options...
