PLAN " B "
bear claw
WOW! that welder writeup is pretty sweet. i suppose you could get fancy and use a set of large aligator clips (like on jumper cables) and attatch them to a length of standard welding lead. i do believe ill add this to my list! already bookmarked
This is for balancing tires. I've been running with it for a few months now and seems to work great . You notice the bead on the steering from 0 to 40 km and then it gets balanced , you need the balancing at higher speed anyway.
There's the site I found the info on this with all the charts and everything.
http://4x4trailhunters.com/article.php?id=18
I bought 2 containers and did 5 tires and have 1/2 left in one.
This makes sense and we should all do this .
I picked the green ones because they look cool even though you don't see them :P
