front seat air bag?
chapter
INSIDE your front seats? i know that there is a such thing as airbags inside the front seats to serve the passengers in the back seats, but this is a safety option on other makes and models. i think that the only other airbags that were in pathies are the side impact and curtain airbags (i believe late R50's and newer) that went along with the dual front seat airbags. if these side impact airbags deploy from the side of your seat...maybe that's what they're for.
Edited by QuismO
i have that adjustable lower lumbar support on mine too, but i just turn a lever and it adjusts the height/depth of what i believe to be a flexible rod/cable in the lower area of the backrest =P
From the Service Manual:
Side Air Bag NARS0033
Front side air bag is built-in type.
The front seatbacks with built-in type side air bag have the labels
shown in figures at left.
From the Owners Manual:
Supplemental side air bag system (if
so equipped)
The supplemental side air bags are located in
the outside of the seatback of the front seats.
The supplemental side air bag (on the driver or
front passenger seat) is designed to inflate in
higher severity side collisions, although it may
inflate if the forces in another type of collision
are similar to those of a higher severity side
impact. It is designed to inflate on the side
where the vehicle is impacted. It may not
inflate in certain side collisions. Vehicle damage
(or lack of it) is not always an indication of
proper supplemental side air bag operation.
When the supplemental side air bags inflate, a
fairly loud noise may be heard, followed by
release of smoke. This smoke is not harmful
and does not indicate a fire, but care should be
taken not to inhale it, as it may cause irritation
and choking. Those with a history of a breathing
condition should get fresh air promptly.
Supplemental side air bags along with the use
of seat belts, help to cushion the impact force
on the head and chest of the front occupants.
They can help save lives and reduce serious
injuries. However, an inflating side air bag may
cause abrasions or other injuries. Side air
bags do not provide restraint to the lower body.
The seat belts should be correctly worn and
the driver and passenger seated upright as far
as practical away from the supplemental side
air bags. Since the side air bags inflate quickly
in order to help protect the front occupants, the
force of the side air bag inflating can increase
the risk of injury if the occupant is too close to
or is against the side air bag module during
inflation. The side air bags will deflate quickly
after the collision is over.
After turning the ignition key to the ON
position, the supplemental air bag warning
light illuminates. The supplemental air bag
warning light will turn off after about 7
seconds if the system is operational.
Need more? :P
Edited by Trainman
Don't have the side airbags, but I'm curious if they're separate units from the seats. It'd be a pain to have the whole seat replaced after they deploy. But then again, if you get hit hard enough from the side to have them deploy, then the car would probably be totaled.
