Gas...
Pathfinder-jay
Could be bad gas......could be colder weather (is it cold where you are) could be wind conditions, could be a clogged fuel filter, could be the tires are low on air.........there's a million things....
I'd say keep an eye on it over the next couple of tanks to see if it clears itself up....if not, then start worrying, and asking questions.
any noticable gas smell? In cold weather, there's a common leak point that may be helping degrade your mileage. Certainly the type of driving has an effect (if you're a lead-foor or a highway granny etc.) If nothing seems obvious, start keeping a log and track your drive style/conditions and mpg (or kpg).
as our cars get older, the gas gauges start to peter out. after driving about 50 miles the needle is all the way on 1/4 tank left on mine. i go strictly by my odometer now
or do you know for a fact that your really burning that much gas? as in..having to fill up multiple times?
usually just need to tighten the hose clamps. Lemme see if I can find a previous post about it...
the link
it's about a half inch dia 3" ling hose that you can see if you look down on the top of your block. I'll get a pic tonight if I can. If you don't smell as, I'm pretty sure that's not your problem
Edited by k9sar
I lifted the hood and was snooping around and found this little tube disconnected from the air intake... The rubbed seemed to have cracked... used some electrical tape for the mean time... and my gas milage is back to normal... weird... anyone know what little tube im talking about?
Thanks
Jason
