Guest poconopaul Posted January 23, 2006 Share Posted January 23, 2006 I have a 2002 Pathfinder. When shut off, the windows will open automaticly. THis happened 3 times so far in the past month. First I thought I left them open but I know for sure the last 2 times they were closed. It only will happen when it's raining(just my luck). I also have a Nissan Altima and it happened on the car as well(once when it was raining). Is this a knows issue that Nissan has? Link to comment Share on other sites More sharing options...
nissandoms47 Posted January 23, 2006 Share Posted January 23, 2006 humm maybe its a relay that isnt sealed good enough. water vapor or water might be entering it and messing up the relay. just an idea. -Alex Link to comment Share on other sites More sharing options...
Trainman Posted January 23, 2006 Share Posted January 23, 2006 If you hold the unlock button down on the remote, the front windows will go down as long as you hold the button, even when not running. Maybe there is an issue with the remote or with the computer (according to the wiring diagram for the windows, the control goes through the computer). Other than that, no clue. The service manual does not list your issue as a problem with a diagnosis flow chart. Link to comment Share on other sites More sharing options...
