Can you fit R16's on a 91 Pathy?
kremmen
no, i don't imagine it would be a problem if they're the same bolt pattern. but since the wheels are now 16", you'll need to replace all your tires because your old ones (probably on your 15" stock rims) won't fit anymore.
I don't think those will fit. It has nothing to do with the 16" rim size, or bolt pattern. The concern is the front calipers on our rigs is a little intrusive when using a rim that has too much backspacing. Those look pretty well flat, and I think you'd be rubbing, ALOT, on the caliper.
The only way to tell is stick one on the front and see. Turn it round and from full lock to lock with the car facing down a slope to put a bit of load on it.
I have Navara offset 15/7" ROH Monsoon mags with 31"/10.5 R 15 rims on my Terrano.
They fit fine but the 15" Navara offset may be for the older Navara. Those newer ones may well have a slightly different clearance with the caliper.
Good luck.
