Vsicks Pathy Posted November 20, 2005 Share Posted November 20, 2005 Just thinking ( i know ) have you checked the wheel bearing's for play if one is loose it will push the pad away :secret: . This can be checked with to much pedal travel if this has been brought up before just tell me to shutup :X It would have been picked up in the front end alignment. Link to comment Share on other sites More sharing options...
94extreme Posted November 20, 2005 Share Posted November 20, 2005 It would have been picked up in the front end alignment. would? well should anyway.. Link to comment Share on other sites More sharing options...
Precise1 Posted November 20, 2005 Share Posted November 20, 2005 i took it to my local independent mechanic who has tried several things to no avail....work he's done:replaced LF caliper replaced brake hoses resurfaced front discs and replaced pads I figure that if the mechanic just had the rotors off, the wheel bearings are probably set correctly... B Link to comment Share on other sites More sharing options...
SteeevO Posted December 1, 2005 Share Posted December 1, 2005 not meaning to steal the thread but .... my strut rod bushings are new but wheel bearings, idler arm, and pitman arm.. all need to be replaced.. so untill i fix all that... i should probably stop complaining Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted December 1, 2005 Share Posted December 1, 2005 not meaning to steal the thread but ....my strut rod bushings are new but wheel bearings, idler arm, and pitman arm.. all need to be replaced.. so untill i fix all that... i should probably stop complaining You lost me on that??? Link to comment Share on other sites More sharing options...
exodus_68 Posted December 1, 2005 Share Posted December 1, 2005 Mine does the same. I spent a while looking at brakes. In my case its the steering. The car gets pigeon toed under heavy breaking which will cause to pull. Might not be the problem in your case...but I had a quick read of all the posts so far and no one has suggested this problem which is pretty common for Pathys with the woeful steering. Not much you can do about it really...make sure all your steering components have good bushes on them or upgrade your steering. The bigger your tyres are the worse the effect is. Link to comment Share on other sites More sharing options...
94extreme Posted December 1, 2005 Share Posted December 1, 2005 Mine does the same. I spent a while looking at brakes. In my case its the steering. The car gets pigeon toed under heavy breaking which will cause to pull.Might not be the problem in your case...but I had a quick read of all the posts so far and no one has suggested this problem which is pretty common for Pathys with the woeful steering. Not much you can do about it really...make sure all your steering components have good bushes on them or upgrade your steering. The bigger your tyres are the worse the effect is. may want to look over the steering components. mine does not do that at all. Link to comment Share on other sites More sharing options...
