Simon Posted November 11, 2005 Share Posted November 11, 2005 That makes sense, but what could cause the high pressure at the fuel line just off the fuel filter. When measured there, it's 65psi, which is before the part of the system you're referring to. Link to comment Share on other sites More sharing options...
k9sar Posted November 11, 2005 Share Posted November 11, 2005 If I look at a diagram of the fuel system, it appears as if the pressure regulator is AFTER the injectors. Guess it uses a back-pressure theory though I'm not sure. There is a line going back to the tank where, if there is no vacuum at the regulator, that line is closed causing a buildup of pressure on the front side of the regulator where the injectors are. Personally, I wouldn't have designed it this way but... oh well Link to comment Share on other sites More sharing options...
02silverpathy Posted November 12, 2005 Share Posted November 12, 2005 Ok so i will try to help narrow the problem myself as I had a prob with my honda too acting goofy about fuel...pull your fuse from the fuel pump and see if it will start and run after trynig to start with the fuel pump getting power. you will first "flood" because of the bad FPR, then remove fuse to kill fuel pump and try to start her...if this works you will have found the problem for sure??? Link to comment Share on other sites More sharing options...
sniper15 Posted November 12, 2005 Author Share Posted November 12, 2005 its not the fuel presure regulator i have just checked it. it hold vacum and now im back to square 1! any ideas the fuel is still at 65psi Link to comment Share on other sites More sharing options...
Precise1 Posted December 6, 2005 Share Posted December 6, 2005 Did you ever get any farther with this Sniper ? B Link to comment Share on other sites More sharing options...
Guest chainsaw Posted December 16, 2005 Share Posted December 16, 2005 pressure before the regulator should be higher than 43psi otherwise what is there to regulate? second, ensure that the connection to the mass air flow sensor is good and that the sensor is working properly. without this sensor the pathy will not run at all! Link to comment Share on other sites More sharing options...
