2WD VG30E in a 4WD Pathy?
Guest pathy91
Guest pathy91
Other than the oil pump, what is the diference between a 2WD VG30E versus a 4WD? I need to swap the engine due to a bent conecting rod and have a 2WD available for cheap with 83k miles. I can save about $400.00 and will complete this swap in about 2 weeks. Please advise...
definately the oil pan and such. Swapping from a 2wd into a 4wd eliminates the frame/crossmember considerations etc. My suggestion is to buy the one from the 2WD and when you pull yours, set them side by side (which you'll probably do anyway to swap your components over) and look for any other differences that would impact the installation. You should be fine.
