Guest jkimes Posted October 11, 2005 Share Posted October 11, 2005 My pathy bounces like a big girl at a dance club any time I hit a bump. I looked underneath it a few weeks ago to figure out the problem and noticed that one of my rear shocks is broken completely in half! :o I'm planning to put in my JGC springs and raise the tortion bars for about a 3" suspension lift, and I ordered a 3" body lift today that should give me 6" of total lift. What size and brand of shocks should I buy to replace my busted rear set since the ride will be higher than stock? Will I need to replace the front shocks as well? Link to comment Share on other sites More sharing options...
wheel366 Posted October 11, 2005 Share Posted October 11, 2005 You only need to get shocks that are 3 inches longer since the body lift is exactly what it says it is, A body lift. Most people go with Rancho 5000. if you do a search, you will find part #'s. If you are doing a full 3 inch susp lift, then yes you will need longer shocks for the front too. Link to comment Share on other sites More sharing options...
BigBikeMike Posted October 12, 2005 Share Posted October 12, 2005 Or you could jack up the back, and keep the front low, and turn it into a drag racer Link to comment Share on other sites More sharing options...
Guest jkimes Posted October 12, 2005 Share Posted October 12, 2005 I checked on the Rancho's shocks and they seem really expensive. What other options do I have? Link to comment Share on other sites More sharing options...
SC88Pathy Posted October 12, 2005 Share Posted October 12, 2005 Rancho shocks expensive? The RS5000 (part number RS5116) are $41 each from www.summitracing.com Doesn't seem to expensive to me. But if you must get cheaper shocks summit also sells skyjacker pro comp and superlift shocks in the $32 to $40 range. Link to comment Share on other sites More sharing options...
Guest jkimes Posted October 12, 2005 Share Posted October 12, 2005 can I use cheap autozone shocks, or are they too short for the JGC's? Link to comment Share on other sites More sharing options...
wheel366 Posted October 12, 2005 Share Posted October 12, 2005 You can order the Calmini shocks for $36.95 each. Calmini 3" Suspension Lift - Shocks Link to comment Share on other sites More sharing options...
SC88Pathy Posted October 12, 2005 Share Posted October 12, 2005 can I use cheap autozone shocks, or are they too short for the JGC's? Yea they probably will be. Then again maybe not, just make sure that they can extend 24 inches and it might be fine. Link to comment Share on other sites More sharing options...
MaritimeMan Posted October 12, 2005 Share Posted October 12, 2005 9K's are great if you don't mind crawling down and adjusting, but spendy. They make a auto adjust kit, but even the salesman at the shop I got the shocks from said not to waste my time with it. 5K's are a good mid road, not too soft, not too hard, react well on the trail. I've also heard good things about Pro Comp's but haven't tried em or payed attention to the response, as I don't have em. Link to comment Share on other sites More sharing options...
