ELEC. POWER TO REAR BED
njbray
I need to put a power supply (cigarette lighter type) in the sidepanel of rear storage area. Any one know where I can wire it in (to be live/hot all of the time ie. even with igntn. off), or do I need to wire it to fuse box/battery.
Thanks for any help.
I would just run a wire back from the Fuse panel or direct from the battery. If you go direct from the battery, fuse it close to the battery. Make sure you use big enough wire so that it doesn't heat up.
The reason I say this is that Nissan sorta went cheap when they wired the Pathys and use something like 24 ga. wire. There is a constant live wire going to the rear cargo light, but I wouldn't want to run much power out of it.
Denis
  • 3 weeks later...
Guest pathyman95
i have a 95 pathfinder and i know in mine their is a factory audio amp on the passenger side behind the removable rear panel if you ran your speakers through the factory wiring that amp should have an all time hot but im not sure it might be worth a look mabey
