njbray Posted September 29, 2005 Share Posted September 29, 2005 I need to put a power supply (cigarette lighter type) in the sidepanel of rear storage area. Any one know where I can wire it in (to be live/hot all of the time ie. even with igntn. off), or do I need to wire it to fuse box/battery. Thanks for any help. Link to comment Share on other sites More sharing options...
nick1716 Posted September 29, 2005 Share Posted September 29, 2005 do you have a sub woofer/amp wire runnin back there at all? Link to comment Share on other sites More sharing options...
gabod7 Posted September 29, 2005 Share Posted September 29, 2005 do you have a sub woofer/amp wire runnin back there at all? i'd be interested in doin the same thing. which wire would i use from my sub and amp? Link to comment Share on other sites More sharing options...
94extreme Posted September 29, 2005 Share Posted September 29, 2005 i'd be interested in doin the same thing. which wire would i use from my sub and amp? the hot one? i am thinking of doing this too but i think i'll run a whole new wire all the way there.. Link to comment Share on other sites More sharing options...
denisb Posted September 30, 2005 Share Posted September 30, 2005 I would just run a wire back from the Fuse panel or direct from the battery. If you go direct from the battery, fuse it close to the battery. Make sure you use big enough wire so that it doesn't heat up. The reason I say this is that Nissan sorta went cheap when they wired the Pathys and use something like 24 ga. wire. There is a constant live wire going to the rear cargo light, but I wouldn't want to run much power out of it. Denis Link to comment Share on other sites More sharing options...
Guest pathyman95 Posted October 22, 2005 Share Posted October 22, 2005 i have a 95 pathfinder and i know in mine their is a factory audio amp on the passenger side behind the removable rear panel if you ran your speakers through the factory wiring that amp should have an all time hot but im not sure it might be worth a look mabey Link to comment Share on other sites More sharing options...
