merlinx Posted September 19, 2005 Share Posted September 19, 2005 Hi all, I have a 97 pathy and I am noticing that the center console might have some parts missing. As you know the it has 2 levels and 2 latches to open the console. I think Im missing a tray or divider of some type. When I open the top part, I can see all the way to the bottom. I think there should be a tray or divider between the 2 levels on the center console. Am I right? Also, Should there be a flap that closes on the lid of the center console? Like to put your wallet or something? There seems to be an indentation on the lid but no flap. I know other cars I have had, had this. Any sugestions on where to get these other than the dealer? The self pick a parts here in southern Cali dont have new trucks like this. Any suggestions would help especially in So Cal. Thanks Jason Link to comment Share on other sites More sharing options...
Trainman Posted September 19, 2005 Share Posted September 19, 2005 Not sure if this helps but.... my 02 has a two part center consol like you describe. And yes it has removable floor from the top compartment. Not sure about the other bit. And I can not help you with any ideas for parts but why not make one from some suitable styrene? Try a hobby shop to get a good thickness (or use some sort of sheet metal like brass or aluminum that is easy to work with). Link to comment Share on other sites More sharing options...
lewisnc100 Posted September 19, 2005 Share Posted September 19, 2005 Yes, it came with a divider tray. I think I took mine out as well shortly after buying my 97, made the bottom compartment too short with it in. Probably has a part# on it if I can find it, or maybe someone else will post it. Link to comment Share on other sites More sharing options...
merlinx Posted September 24, 2005 Author Share Posted September 24, 2005 Well, after finding out that the dealer wanted $30 for the divider I decided to find one in the junk yard. Funny, nobody had one. I ended up making it my self. What I did was make it into 3 separate campartments. I glued a piece of hard board on the bottom of the lower part of the campartment then I made a piece of plexi glass fit perfectly and screwed a little knob. Its kinda cool cause I can store the stuff I hardly use at the bottom part and the rest I sort accordingly. Link to comment Share on other sites More sharing options...
